S/RS Sport-Layout on A4
Hi all, quick write-up. I spent some time this weekend trying to figure out enabling sport-layout on VC on non-S/RS cars. Here's a quick tutorial for those whose cars have less than 100 km (60 miles) that I found on a Chinese forum. Once the cars are past 100 km, this can no longer be used. There are other methods for those vehicles that you generally have to pay for.
OBD 11 instructions:
- go to dashboard [17]
- adaptation
- designvariant activation
- designvariant_activation-1
turn your car off for 5 min. Once you turn it back on, you should be able to access sport-layout functionality and change the design of your VC.
- adaptation
vkamnyev (01-26-2021)
i hope someone soon will leak the knowledge on patching the VC to enable RS/S dial.. i think it's a matter of time before someone decides to leak it all, like MIB2 patching
thanks for sharing!
thanks for sharing!
There is a hack to enable the single dial layout which involves installing a modified radio head which does something to the MMI which then enables single dial mode, however it is not switchable. It stays in single dial mode all the time and the only way back to to go through a multi-hour uninstallation process. I think it's on youtube, but I've seen discussion in either audisport or audizine.
https://www.youtube.com/watch?v=E5qd...nel=YaodeChain
I am trying to find a way to telnet VC, unsuccessful so far. i cant keep the developer mode active permanently
bniner (01-26-2021)
i believe you are referring to this video ?
There's definitely a better patch that enables all of the functionality (including switching between sport and standard layout) and does not require any hardware modifications. It is available in Russia by Audi-Rus and costs around $200. See links to the product and reviews below. If you do not speak Russian, you can use Chrome to auto-translate. I think it consists of an FEC patch + VC FW update without the 100 km limitation and then designvariant activation.
Product
Review 1
Review 2
Review 3
Review 4
Review 5
Review 6
Review 7
Product
Review 1
Review 2
Review 3
Review 4
Review 5
Review 6
Review 7
bniner (01-26-2021)
What I learned today - Audi Riviera Blue is the same color as blue painters tape
Product
Review 1
Review 2
Review 3
Review 4
Review 5
Review 6
Review 7
Product
Review 1
Review 2
Review 3
Review 4
Review 5
Review 6
Review 7
I am looking for that VC FW without 100km limitation. I havent seen that anywhere. but with this method i think we are only scratching the surfacce. There is soo much more that hasnnt been released yet, its probably been in dev for severall years and only made the rounds a year ago on the net and only on the international ones. I havent seen it on any US sites (forums alike)
I stumbled upon an S5 VC and installed semi-succesfully in my A4 (just need a cable to get maps, arriving from overseas). This allows me to switch between the one gauge "Sport" layout and the "Classic" layout anytime with ongoing swutchability beyond 100km. The cost was C$850 for the cluster and $C160 to get Component Protection removed. It works perfectly once I coded out adaptive suspension and all wheel steering, which took two seconds with OBDEleven.
All of which is to say, it may be more cost effective to wait for an S4/S5/RS5 cluster to show up on eBay or your local wreckers. The install is quite straight forward.
ugh why do I waste my time!! I'm arguing with a Subaru owner that our cars turn more heads than his.
kTTang
05-26-2008 11:36 AM
Audicted
Audi Original "S" Cars
10
05-22-2007 09:04 PM
Shep 1.8T
08-29-2004 05:57 PM
TaciTrequiem
08-21-2004 02:49 PM
Senna4Life
02-18-2002 06:20 AM
