How to turn off Radio w/o turning off MMI
Ok...I have read the manual over and over again and gone through the MMI menu several times. I must be missing it or this is a bad design flaw....
How the heck do I turn off the radio without turning off the MMI screen.
And I am not talking about going to another input like media.......I just want to know if there is a way to turn off the radio in case I would like peace and quiet, but still need the ability to use the MMI
I'll ask a parallel question: on media, every time I start the car the music comes on - it there a way to prevent it?
I'll try to be a little bit more clear.....when I turn on the car, the radio comes on, whether it is FM, AM or siriusXM...... If I change to media then the radio stops....if I select menu, the radio keeps playing, if I plug in my iphone, carplay connects, but unless I choose music on car play, the radio still plays....
If I push and hold the small round **** on the right hand side of the MMI wheel, then the radio and MMI turn of. If I just push and let go quickly, it mutes the radio, if I push it left or right, it changes the station...... the same is true about the control on the steering wheel
I want to be able to completely turn off the radio while still having the functionality of the other items within the MMI.....
Press the steering wheel volume button or the center console volume button and it will mute/pause the audio source you are currently listening to including the radio.
Ok, I do get that I can mute the radio/audio source by pressing down on the button, but again, I want to know if there is a way to turn off the radio/audio source without turning off the MMI......I get that this might be a flaw in the design and if it is, then ok, I'll live with it, but so far no one has told me whether or not it can be done.
Since the first generation of MMI I believe it has been the same.
If muted when shut down, there is a "Minumum Sound Level" setting that takes Mute OFF and sets the level at the next ignition ON.
For the B8 there is a work-around. The "Minumum Sound Level" can be changed to zero by using the "Hidden/Green Menu". It still doesn't remember Mute but when I want silence for a while I reduce the audio level to zero. It then allows the sound to be off.
While this isn't applicable directly on the B9 system, maybe someone can look for a similar setting and work-around (using VCDS or similar).
