https://static.nhtsa.gov/
Old Feb 21, 2024 | 04:36 PM
jase85's Avatar
Default https://static.nhtsa.gov/
I was replacing the pump and fluid came out, i dont know if I refill it with the same a.t.f fluid that came out or something different i used g 055 529 a2. and pumped it into the plastic pan top where you check the level .
i was reading the tsb and it mentions stuff about M.T.F fluid , but it is an automatic so i used automatic a.t.f fluid , and through the check level instead of directly into the transmission itself. torx 30 metal plug.
when checking the level at 100 degrees the same amount of fluid came back out
so if someone had the repair manual for https://static.nhtsa.gov/odi/tsbs/20...53066-9999.pdf
RAvent25
Aug 8, 2019 03:43 AM
lrwatkins
Sep 13, 2010 05:44 AM
SpeedyG127
Feb 18, 2007 03:34 PM
BaysideRS4
13
Feb 2, 2004 11:05 AM
Andyr_123
Audi 100 / A6 (C4 Platform)
Oct 28, 2003 06:15 PM
