JB4 Information thread for 2.0T 252hp
We would like to introduce users to our latest offering.
The unit is called a JB4 which is the name of our most advanced circuit board with CANbus connection (vehicle data network). It has been tried and tested over many BMW models and it is time for the evolution to start for the VW market.
Upgrade units for JB1 users are available to at this link, both revision 1 and 2 units can be upgraded: http://www.burgertuning.com/vw_audi_eA888_JB4_upgrade_kit.htmlhttp://www.burgertuning.com/vw_audi_eA888_JB4_upgrade_kit.html"]http://www.burgertuning.com/vw_audi_eA888_JB4_upgrade_kit.html[/URL]
Complete JB4 Beta units can be found at this link: http://www.burgertuning.com/vw_volkswagen_Group1_JB1_tuner.htmlhttp://www.burgertuning.com/vw_volkswagen_Group1_JB1_tuner.html"]http://www.burgertuning.com/vw_volkswagen_Group1_JB1_tuner.html[/B]
The JB4 is a true plug and play tune offering safe and adjustable gains.
The unit ships with a base setting in map 1 that increases the boost by +4.0psi over stock that is safe to be used with 91US octane and 95 Euro.
Install instructions:
Install instructions can be found here: http://www.burgertuning.com/instructions/VW_JB4_install.pdfhttp://www.burgertuning.com/instructions/VW_JB4_install.pdf"]http://www.burgertuning.com/instructions/VW_JB4_install.pdf[/URL]
JB1 to JB4 update instructions can be found here: http://www.burgertuning.com/instructions/JB1_to_JB4_upgrade_procedure.pdfhttp://www.burgertuning.com/instructions/JB1_to_JB4_upgrade_procedure.pdf"]http://www.burgertuning.com/instructions/JB1_to_JB4_upgrade_procedure.pdf[/URL]
The JB1 to JB4 upgrade kit can be bought here: http://www.burgertuning.com/vw_audi_eA888_JB4_upgrade_kit.htmlhttp://www.burgertuning.com/vw_audi_eA888_JB4_upgrade_kit.html"]http://www.burgertuning.com/vw_audi_eA888_JB4_upgrade_kit.html[/URL]
Connectivity:
To connect to the unit to make changes or do logs you have two options:
1. Laptop connection using our BMS Data Cable via free Windows and Mac software. (conventional serial cables will not work and possibly damage the board).
2. Via Bluetooth using our JB4 Connect kit that is IOS and Android compatible. The Bluetooth device replaces the need for our BMS Data Cable. On some Android devices users have has success connecting using our Data Cable. The App for the handset has a separate charge and can be found in the Google play store or App store as JB4 Connect.
The App can also be used for a gauge displaying showing true values, has shift light capability and acceleration times are being worked on.
JB4 connect link here: http://www.burgertuning.com/bluetooth_jb4_connect_kit.htmlhttp://www.burgertuning.com/bluetooth_jb4_connect_kit.html"]http://www.burgertuning.com/bluetooth_jb4_connect_kit.html[/URL]
User interface software:
For users that have opted to purchase the optional but recommended for JB4 BMS Data Cable you will need to download and install the Windows user interface at this link http://www.n54tech.com/flash_files/jb4_interface.ziphttp://www.n54tech.com/flash_files/jb4_interface.zip"]http://www.n54tech.com/flash_files/jb4_interface.zip[/URL]
There is a 3rd Party Developed Mac interface that can also be used, download link can be found here at bottom of post 1 http://www.n54tech.com/forums/showthread.php?t=21742http://www.n54tech.com/forums/showthread.php?t=21742"]http://www.n54tech.com/forums/showthread.php?t=21742[/URL]
Tutorial of how to install User interface software, connect to unit and make changes.
Video of user interface install and connection: https://www.youtube.com/watch?v=MjQjMWBVve4[/ame]https://www.youtube.com/watch?v=MjQjMWBVve4"]https://www.youtube.com/watch?v=MjQjMWBVve4[/ame]
Directions on installing the interface and connecting to your JB can be found here http://www.n54tech.com/forums/showpo...21&postcount=1
Firmware is what runs the JB4 unit. As we release new firmware it will be added to post 3 here.
Base settings
If you need to restore your unit with the settings the JB4 shipped with use the below values.
Map selection:
In order to change the map in the picture below under the logging tab you can pick the required map. Under status the unit must show connected. This is done by clicking file and selecting connect.
Upon shipping the following maps are active:
Map 0: Stock with complete pass through i.e. the JB4 does nothing
Map 1: Tuned map with a average of 4.5psi over stock. This is the shipped map and is compatible for both 91 and 93 and can be used with cars on hardware.
Map 2: This map is a more aggressive map. Peak boost is set to 24psi with a taper down to 16psi at redline.
Map 4: This is a stock map but with JB4 logging ability. It is also the starter map for cars that are running flash tunes and are stacking the JB4. It will give the ability to log the car via the JB4. This is also the safety map, so in any circumstance the JB4 detects a unsafe condition regardless of map it will default to this map. This includes knock detection, lean AFR or the boost safety value being triggered due to lack of boost control.
Map 6: User adjustable boost map. The map comes preset with a 5.0psi over stock peak and is ready to use on any car running 93 octane. The preset map is also suitable for manual cars with clutch longevity in mind.
The mapping can be done in two manners. If the value at 1500 is kept below 10 it will work as a boost adder map. If the value at 1500 is higher than 10 it will work as a absolute map. This means actual total boost targets will need to be entered.
User Adjustment page:
Below is a outline of settings that can be changed in the User adjustment page:
Map 6 (blue outline): as explained above
AFR Bias (red outline): This value is to be set across the range at 100. It is the parameter which adjust the AFR ratio. Unless otherwise advised by us its should be left alone. For cars using the JB4 over a flash tune this value will start of at 0 across the rpm range and working on logs we will advise the end user on the settings.
Boost safety (green outline): This value is a boost ceiling that user will set. It is recommended the value of this is 2psi over peak tuned map. i.e. if you hitting 24psi set this at 26psi. If for whatever reason the car over boosts it will default straight to map 4 returning the car to the stock tune.
Fuel Open Loop (purple outline): This value is what controls the rail pressure to keep fuel trims in check. It is used to avoid having the ECU compensate fuel for the unseen boost. The unit ships with a 40 value. Upon logging some users with hardware may need to raise this value. The ceiling on most cars is 60. For users that are stacking the JB4 over a flash tune this value will be set to 0 initially and via logs we will see if it needs to be raised to compensate for the small boost add.
Max boost add (pink outline): These values represent the maximum boost allowed in each gear with the minimum value being the stock tunes value. If you are using boost add values in map 6 you will add the amount of add you want max. i.e. If your high rpm values are set at 5.5 and you do not want any boost in first you will set the value to .1. If you want only 2psi add over stock you will set it to 2. This is the methodology you will use if you running the JB4 over a flash tune as well. Future firmware updates will be able to remove boost even below the stock request.
For users that are entering absolute values and say your peak is 24psi, you will enter the lowest you want allowed. Stock is around 17psi so you can do first for stock, 19 for second and so forth.
Code and Fault reading: At first release the unit will only be able to read faults in Hex Code and clear them. The next firmware update will bring the translation of the code into the user interface as well as activate the autoclear feature for users with **’s.
For now use E Series N54 in the setting page:
Logging:
The JB4 now has full logging ability and all the parameters on the logging page are logged. The only three parameters to be added in the next firmware update is the oil temp, water temp and transmission temp.
Ign 1 represent overall timing with Ign 2-5 timing adaption and the rest are self explanatory. IAT is the value in F x10.
More on logging in post 2
Below a illustration of what a log will look like with a lot of parameters selected on display.
FIRMWARE UPDATES
The JB4 firmware is in post #3. To upload it connect to your JB4 unit (Key on but engine not idling). Go to File then Upload firmware and select the saved file from your laptop. If the upload fails try again without disconnected.
For phone apps follow the instructions at this link: http://jb4connectkit.com/store/index.php?route=information/information&information_id=10http://jb4connectkit.com/store/index.php?route=information/information&information_id=10"]http://jb4connectkit.com/store/index.php?route=information/information&information_id=10 Make sure you browse back to this thread to select the correct firmware.
Latest version is the VW_JB4_OBDII_6B which will reflect as 60/5//5 in the firmware window once connected.
FAQ:
Can I run the JB4 with another device connected to the CANbus?
No, any other device connected to the OBD port creates latency on the CANbus. The CANbus was designed to allow one device at a time and further data being pulled may create safety issues on the network as well as bad signal to the JB4
Will BMS release cluster display and steering wheel map switching?
At this stage cluster hijack has proven to be cost prohibitive due to the Gateway system used by VW. We are looking at getting cheaper solutions that may be affordable. Steering wheel map switching or in car map switching is something being worked on and will come in a future firmware update.
What future features will the JB4 have?
Currently we working on the code reading ability which will come as the first firmware update. Next in line is an Autotune map. Once we have gathered enough data we will be able to create a dynamic map that will self adjust on the fly maximizing performance regardless of conditions, mods and octane used.
Why is the JB4 released as Beta?
When we release units they stay in Beta for quite a while. Any updates done to the unit are firmware related so they get uploaded using the BMS Data Cable.
The JB1 stayed in Beta for a year with only one update when we opened map 6 use.
The JB4 will be ever evolving as we keep adding features to it relative to customer requests.
Will the JB4 remove my speed limiter?
At this point in time, no. The speed limiter affects many safety parameters and until we are certain there are no ill effects on this we will not have speed limiter removal available. The speed limit exceeded is also a trigger point logged in the ECU which may cause issues down the line for any form of claim.
Can launch control be added for a manual car?
No, at this stage this requires changes in the ECU structure which the JB4 does not access or tamper with. We have had success with this on other brands with add on hardware so its something we to intend down the line.
Can the JB4 support larger turbos?
At this stage on the 1.8T we can support the IS20 and on the GTI the IS38. On the R any larger frame turbo will require a flash of some sort.
How do I know if I can stack the JB4 over my flash tune and what is the process?
This varies on what the flash tune is requesting from the car and if there is room for improvement. If more hardware is used, higher octane or ethanol or meth has been added chances are there is a gain to be had. On stack tuned cars we work one on one with clients so we can understand the trend and get a better idea for the community where gains can be had.
Do I need a professional to custom tune my car if I want more power than the preset maps?
BMS is renowned for its customer service and we can assist any customer with setting his car up to optimize performance. A large online community exists as well where users share their findings. The device works in such a way that it is easy for first time enthusiasts to get a taste of self tuning.
Why does the JB4 read my Vin number and is it Vin locked?
The Vin is read for certain mapping purposes. The unit is not locked to the car which would be unethical and can be resold.
Why is the JB4 cheaper than other options yet more advanced?
The circuit board used in the VW product has been used over many other brands and developed over a period of time so the development cost is spread over many models.
For any questions feel free to post here or email me George@burgertuning.com for a faster response.
Below is a dyno sheet from one of our testers running 91 octane. Power is corrected to the flywheel, torque is in Nm.
Connectivity:
Base settings
Map selection:
Logging:
FIRMWARE UPDATES
FAQ:
JB1 info
The JB1 is a simpler plug and play unit. It still maintains the fueling element of the JB4 but does not have network connectivity.
The unit is designed to be more of a plug and play solution with a easy install process giving gains of 45hp and 65ft lb of torque on 91oct.
Install instruction:
http://www.burgertuning.com/images/d...tall_guide.jpg
User that decide to go this route will have the capability of upgrading their units down the line to JB4's by buying the upgrade kit.
Cool stuff George! BMS has been fantastic in the BMW space, glad to see they are making strides in the VW and Audi community too. Are the numbers you put in this post correct? It says +55HP and +60ft/lbs for the JB4 but +45HP and +65HP for the JB1. I would assume with the adjustment the JB4 makes on the fly via the ODB2 that the number would be at least the same or higher for torque on Map1
JB1 info
Why does the JB1 + Upgrade kit cost so much more than just buying a JB4? JB4 is $50 more than JB1 but Upgrade kit is $125?
For the Bluetooth Wireless Kit, there's Grey Shell Rev1 and Without Grey Shell Rev2 and JB4. What does this mean and how does it relate to JB1/JB4 module? That is, which one to buy if I'm getting a JB1 or JB4?
If I buy the JB4, can I use it as a JB1 if I don't want to run the OBD connection?
The upgrade kits includes a new circuit board (JB4) as well as the wiring required to upgrade the JB1 unit
The correct Wireless or Data cable is without Grey shell for Rev2 and JB4. There was a enclosure update where the connection is now inside the box so the shell/cover is not needed anymore.
Can somebody explain the rationale behind using a piggyback unit vs an ECU flash. I'm coming from the Subaru world, so piggybacks are non-existent and tuning is usually done with a Cobb Accessport (or similar opensource PC software) which plugs into the OBD port and allows flashing and unflashing of multiple ECU remaps on demand. For example I had a custom 93 octane maps, an Off the shelf 93 and 91 octane maps, and the stock map and could change between these by reflashing. These maps had access to change a bunch of parameters , most importantly ignition timing, AFR targets , boost targets, and cam advance. For example my usual tune increased the boost peak by 4-5 psi but needed a cooresponding decrease in timing at peak torque and increased fueling to hit those levels safely without knock. This tune worked flawlessly.
I'm not familiar with ECU remapping in the Audi / VW world, so what parameters other than boost can a piggyback do? It's my understanding that the piggyback intercepts sensor output from the O2 sensor, boost vac sensor and changes what the ECU sees. Does this introduce some latency in the system? What advantage does this have over a flashed ECU tune? The only other tune I saw on here is an APR off the shelf tune, and apparently this can't be flashed or unflashed at will by the end user. Is there anything that works like that for the
Sorry for the noob questions, hope I can get some insight here.
Our units are most likely the most advanced available as we have AFR bias, rail pressure biasing, boost control over rpm and adaption for knock running in the back ground. We can see all engine parameters required to run the car efficiently getting similar results to cars that are flashed tuned.
There are several advantages of running our piggy back vs a tune. For one it can be resold after use or possibly moved on to the next car. You have the freedom of fitting it yourself and removing it when you want too. There is boost per gear capability as well as built in logging and fault reading with gauge viewing capability if you go bluetooth. You can optimize the car yourself with it as well as use several maps for different circumstances like E85 mixes etc. Further than that it leaves the ECU untouched for when you want to revert the car back to factory spec.
Map 1 peaks 4.0psi over stock from around 4500rpm. Map 2 peaks 5.4psi from around 5250. Map 2 is similar to the map 6 setting. If guys with 93 want to run it email me data logs to George@burgertuning.com and I can see if its ok. In the UK where the temps are lower year round and their fuel quality is slightly better its fine to run.
