Limp mode
Limp mode
Hi All,
Had a fun issue happen today. Went to go stand on it merging onto the highway and heard a nice pop and now it wont go into boost, at all. I get a Drive System Malfunction and a speed control unit malfunction that turns off the cruise control. I have had a racechip installed in it for the last year and a half or so and removed it right after it happened. It is still in limp mode and its starting to worry me.
Any one had any issues with it and is the racechip going to cause a td1? I am going to let it sit overnight but i have driven it around the block to see if the ECU will clear itself and it hasnt...
If you heard a pop you probably blew something. I would try to borrow a VAGCOM and scan for codes, if you don't have one then you'll need to take it into a shop or the dealer to get it scanned.
And yes, if dealership detects or suspects that a car has been tuned or modified, they will almost certainly TD1 your car. Piggyback tunes are harder to detect but it's always a possibility and if you have other mods or a bunch of Racechip stickers on your car then it could prompt them to look harder / scan the ECU for parameters that seem abnormal and that are consistent with running an external tune. That is always the risk you take when you tune a car that is under warranty.
And if it turns out you blew a turbo while running a tune, and then mislead the dealer into replacing it under warranty by hiding a tune that would otherwise disqualify it, then FYI that that is technically criminal fraud.
Bring the car to the dealership, don't admit you had a chip. If they find evidence and flag your car, you're SOL. If they don't see anything that would make them deny the claim, then they'll fix it and don't worry about it.
I’m not advocating for any particular course of actions but that is a possibility OP should acknowledge. How common this is who knows, but from a legal perspective this is no different than falsifying an insurance claim. The penalties if caught are severe.
Looks like it was a intake air temp sensor and a lower boost hose that was disconnected. All of it was covered under warranty and per audi, there is a known issue with the sensor.
greenaudi100
Audi Original "S" Cars
12-04-2009 10:40 PM
davenew
09-17-2005 12:14 PM
