Need Help with theses codes!!!
Old Nov 4, 2025 | 04:47 PM
oneisis15's Avatar
Default Need Help with theses codes!!!
Tuesday,04,November,2025,20:18:23:44348
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 arm64(arm64 CPU)(Parallels)
VCDS Version 25.3.2.0 (arm64) HEX-V2 CB: 0.4671.5
Data version: 20250822 DS365.0
www.Ross-Tech.com
VIN: WAUZZZF49GA023175 License Plate:
Chassis Type: F4-AU49 (4M1)
Scan: 01 02 03 08 09 15 16 17 19 42 44 46 52 5F 81 BB BC
VIN: WAUZZZF49GA023175 Mileage: 68548km-42593miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
81-Gear Shift -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (MA----CVKB) Labels:. 06L-907-115-V1.clb
Part No SW: 8W0 907 115 K HW: 06L 907 309 A
Component: 2.0 R4 TFSI H40 0003
Revision: S1H40--- CVN: A52E9BC7
Coding: 0A2510132304050034000000000000000000000000000000
Shop #: WSC 27932 002 1048576
ASAM Dataset: EV_ECM20TFS0118W0907115K 001004
ROD: EV_ECM20TFS0118W0907115K.rod
VCID: 41D899A0B10319C2C1D-8015
VINID: 9D196AAAA58425744008304714E4F7F537
No fault code found.
Readiness: 0010 0001
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 8W0 927 155 B HW: 0CK 927 156 S
Component: 0CK 20TFSIRdW H04 0007
Revision: --H04--- Serial number: 0000000868 CVN: A6830AE8
Coding: 000001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDL382021 002021
ROD: EV_TCMDL382021_AU49.rod
VCID: 3E22E25CC0FD663ABCF-806B
MTF pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP HB1 0572
Serial number: 75117051150324000882
1 Fault Found:
21016 - FlexRay Databus
U0080 00 [00100000] - Defective
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Mileage: 68536 km
Date: 2025.10.28
Time: 18:08:47
Engine speed: 0 /min
Driving position: P
ATF temperature: 60 °C
Transmission output speed: 0 /min
Voltage terminal 30: 12.2 V
Engine torque: -16 Nm
selected gear: 1
Ctrl. mod.: operating condition: regular operation
Auxiliary pump for transmission: requesting function: No function active
Auxiliary hydraulic pump for transmission oil: current: 0 A
Oil pressure reservoir: pressure: 26.1 bar
Pressure of clutch 1: actual value: 0.0 bar
Pressure of clutch 2: actual value: 0.0 bar
Clutch status: Neutral
Unlearning counter according OBD: 39
Occurrence_counter_over_length_of_life: 255
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-V1.clb
Part No SW: 8W0 907 379 E HW: 8W0 907 379 J
Component: ESP9 Plus H06 0593
Dataset Number: 8W0909504VA 0001 CVN: B0FDBA67
Coding: 04AA089910A40A99159F489800825292E6A5C020100850A812 004A4967A503
ASAM Dataset: EV_ESP9BOSCHAU49X 012014
ROD: EV_ESP9BOSCHAU49X_012.rod
VCID: 47CC87B89F2727F20F9-8013
19 Faults Found:
488448 - Databus
U1121 00 [00101000] - Missing Message
[ComScl:_PDU_Motor_01_-_Timeout_error]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 68536 km
Date: 2025.10.28
Time: 18:16:11
77 40 82 00 CA 24 00 50 00 00
359936 - Databus
[ComScl:_PDU_Motor_18-_Timeout_error]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 68536 km
Date: 2025.10.28
Time: 18:16:13
76 40 82 00 CA 24 00 50 00 00
356352 - Databus
[ComScl:_PDU_Motor_35-_Timeout_error]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 68536 km
Date: 2025.10.28
Time: 18:16:09
78 40 82 00 CA 24 00 50 00 00
12648455 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [00101000] - -
[ComScl:_PDU_OBD_01-_Timeout_error]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 68536 km
Date: 2025.10.28
Time: 18:16:09
276224 - Databus
[ComScl:_Signal_Group_SG_Getriebe_11-_Timeout_error]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Mileage: 68536 km
Date: 2025.10.28
Time: 18:16:08
12648704 - No Communication with Transmission Control Module
U0101 00 [00100000] - -
[ComScl:_Signal_Group_SG_Getriebe_13-_Timeout_error]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 68536 km
Date: 2025.10.28
Time: 18:16:08
473088 - Databus
[ComScl:_Signal_Group_SG_Getriebe_15-_Timeout_error]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Mileage: 68536 km
Date: 2025.10.28
Time: 18:16:08
278272 - Databus
[ComScl:_Signal_Group_SG_LH_EPS_02-_Timeout_error]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 68536 km
Date: 2025.10.28
Time: 18:16:08
279040 - Databus
[ComScl:_Signal_Group_SG_LH_EPS_03-_Timeout_error]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 68536 km
Date: 2025.10.28
Time: 18:16:08
12648454 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [00100000] - -
[ComScl:_Signal_Group_SG_Motor_11-_Timeout_error]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 68536 km
Date: 2025.10.28
Time: 18:16:08
12648449 - No Communication with Engine Control Module (SAE ECM/PCM)
[ComScl:_Signal_Group_SG_Motor_12-_Timeout_error]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 68536 km
Date: 2025.10.28
Time: 18:16:08
12648450 - No Communication with Engine Control Module (SAE ECM/PCM)
[ComScl:_Signal_Group_SG_Motor_14-_Timeout_error]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 68536 km
Date: 2025.10.28
Time: 18:16:08
12648451 - No Communication with Engine Control Module (SAE ECM/PCM)
[ComScl:_Signal_Group_SG_Motor_20-_Timeout_error]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 68536 km
Date: 2025.10.28
Time: 18:16:08
15386112 - Databus
[ComScl:_PDU_Motor_28-_Timeout_error]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 68536 km
Date: 2025.10.28
Time: 18:16:08
12648452 - No Communication with Engine Control Module (SAE ECM/PCM)
[ComScl:_Signal_Group_SG_Motor_Code_01-_Timeout_error]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 68536 km
Date: 2025.10.28
Time: 18:16:08
12669184 - No Communications with Airbag Control Module
U0151 00 [00100000] - -
[ComScl:_Signal_Group_SG_SARA_06-_Timeout_error]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 68547 km
Date: 2025.11.04
Time: 18:21:56
7D 00 82 00 42 00 00 00 00 00
288512 - Databus
[ComScl:_Signal_Group_SG_TSK_06-_Timeout_error]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 68536 km
Date: 2025.10.28
Time: 18:16:08
360960 - Databus
[ComScl:_Signal_Group_SG_TSK_08-_Timeout_error]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 68536 km
Date: 2025.10.28
Time: 18:16:08
12615680 - FlexRay Databus
U0080 00 [00101000] - Defective
[FlexRay_controller_0_channel_A_no_synchronisation]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 68547 km
Date: 2025.11.04
Time: 18:21:56
7D 00 82 00 42 00 00 50 00 00
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 L HW: 8W0 820 043 L
Component: Klima Zone 1 H40 0055
Coding: 14080188514000051000010000000000000000000000000000 0000000000
Shop #: WSC 06325 790 00001
ASAM Dataset: EV_AirCondiBHTCAU491 001013
ROD: EV_AirCondiBHTCAU491.rod
VCID: 3C26E854D6E1742A92B-8069
Fresh air blower control module (front):
Subsystem 1 - Part No SW: 4M1 820 021 HW: 4M1 820 021
Component: J216 FLuftV H05 0001
Serial number: 00000000000000675605
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4G0 907 658 B HW: 4G0 907 658 B
Component: Humidity_Sens H01 0003
Serial number: 3C4806D7000000000001
3 Faults Found:
459014 - Databus
U1121 00 [00011000] - Missing Message
Intermittent - Confirmed - Not Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 212
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:10
459023 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 212
Mileage: 68536 km
Date: 2025.10.28
Time: 17:52:56
459532 - Databus
U1123 00 [00001000] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 145
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 15:55:28
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W0 907 063 AC HW: 8W0 907 063 C
Component: BCM1 MLBevo H12 0229
Dataset Number: 8W0909514VF 0001
Coding: 80453942451800CD01140010182800F9100331000000000000 00000000001A2000400022003000
Shop #: WSC 06342 790 00001
ASAM Dataset: EV_BCM1BOSCHAU736 015005
ROD: EV_BCM1BOSCHAU736_015.rod
VCID: 7CA628549661B42AD2B-8029
Wiper motor control module:
Subsystem 1 - Part No SW: 8W1 955 119 HW: 8V1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS491 151009 043 0813
Serial number: 894353?0401528200944
Coding: 5BC7F7
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 60967409
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 N HW: 4M0 941 531 N
Component: E1 - LDS H06 0008
Serial number: 16 09 2015 00102186
Automatic dimming interior mirror:
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE123101511910575
Coding: 010000
Interior Light Module:
Subsystem 5 - Part No SW: 8W0 947 135 D HW: 8W0 947 135
Component: J528-Dachele H13 0080
Serial number: Q00020665
Control head for driving and comfort functions:
Subsystem 6 - Part No SW: 8W0 925 301 AT HW: 8W0 925 301 AT
Component: SL-B9/Q5NF H15 0010
Serial number: 2815000133093004
Coding: 000000
7 Faults Found:
65859 - Databus
U1121 00 [00001000] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:52:57
average_Voltage_terminals: 12.00 V
Outside air temperature sensor-Resistance: 0.00 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 34.00 °C
interior_temperature: 31.50 °C
Vehicle speed: 0.00 km/h
Terminal activation-Terminal 75 status: On
Terminal activation-Terminal 15 status signal: On
Terminal activation-Terminal 15 via CAN: On
Terminal activation-Term 75: qualification: OFF
65861 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 216
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 15:55:27
average_Voltage_terminals: 14.00 V
Outside air temperature sensor-Outside air temperature on CAN: 34.50 °C
interior_temperature: 28.00 °C
65876 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:14
Outside air temperature sensor-Outside air temperature on CAN: 31.00 °C
65877 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:10
average_Voltage_terminals: 11.80 V
65904 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 180
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 15:56:47
average_Voltage_terminals: 13.10 V
Outside air temperature sensor-Outside air temperature on CAN: 36.50 °C
196758 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 18
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 15:55:28
196899 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 121
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 15:55:28
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 HW: 8W0 959 655
Component: Airbag10.44 H52 0084
Serial number: 003M6000LVSP Dataset Number: 8W0909602Q 0001
Coding: AECCF0000080000058000033C00C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005012
ROD: EV_AirbaAU10BPAAU736_005.rod
VCID: 06524ABCD8ADFEFAB4F-8053
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2033
Serial number: 8W0857705A0320P01211
Coding: 88001B
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2033
Serial number: 8W0857706A0316P00507
Coding: 88001B
Crash sensor for side airbag: driver side:
Subsystem 3 - Part No SW: ----------- HW: 442 060 511 15
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y00C31A87822608.
Coding: 2D2D2D
Crash sensor for side airbag: passenger side:
Subsystem 4 - Part No SW: ----------- HW: 442 060 611 15
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y00A51A87825024X
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 5 - Part No SW: ----------- HW: 442 0B2 010 15
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700BB1D4A1D261DN
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 6 - Part No SW: ----------- HW: 442 0B2 010 15
Component: SideSensor_Pr 1C7 0148
Serial number: 3527700BB1D4A1D3742I
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 7 - Part No SW: ----------- HW: 442 0C0 711 15
Component: FrontSensor_D 1C5 014A
Serial number: 3557500C51D690F4B1BR
Coding: 2D2D2D
Crash sensor for front airbag: passenger side:
Subsystem 8 - Part No SW: ----------- HW: 442 0C0 711 15
Component: FrontSensor_P 1C5 014A
Serial number: 3567500C51D690F5014B
Coding: 2D2D2D
13 Faults Found:
1049344 - Databus
[NWD: 0x103 ESP_03 Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:10
1052672 - Databus
[NWD: 0x392 ESP_07 Timeout]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:10
1055232 - Databus
[NWD: 0x11E ESP_08 Timeout]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:10
1052928 - Databus
[NWD: 0x0FD ESP_21 Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:10
1052416 - Databus
[NWD: 0x106 ESP_05 Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:10
1057792 - Databus
[NWD: 0x0A8 Motor_12 Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:52:54
1053952 - Databus
[NWD: 0x121 Motor_20 Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:52:54
1056000 - Databus
[NWD: 0x3BE Motor_14 Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:52:54
1062144 - Databus
[NWD: 0x1AB ESP_33 Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:10
1061888 - Databus
[NWD: 0x0A0 LH_EPS_04 Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 181
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 15:56:46
1061893 - Databus
[NWD: 0x0A0 LH_EPS_04 error value EPS_Zahnstangen_Pos]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 214
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 15:55:06
1068800 - Databus
[NWD: 0xTBD ESP_28 Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:10
1063168 - Databus
[NWD: 0x104 EPB_01 Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:10
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 GT HW: 4M0 907 129 GT
Component: Lenks.Modul H11 0008
ASAM Dataset: EV_SMLSKLOAU736 006008
ROD: EV_SMLSKLOAU736_006.rod
VCID: 084E4484D2B9E88AC63-805D
1 Fault Found:
4194560 - Databus
[Empfangstimeout ESP]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:10
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 740 HW: 8W5 920 740
Component: MM--M--BENRW- H06 0267
Revision: 0226v3 Serial number: LL2C2YDBR
Coding: 04A450C0288000080500A8001000000000000000
ASAM Dataset: EV_DashBoardAU736 001022
ROD: EV_DashBoardAU736_AU49.rod
VCID: 7AAA2E4C9C558A1AC07-802F
7 Faults Found:
16776968 - Databus
[ESP_24 communication error can_error_timeout]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 253
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:11
16776971 - Databus
[Motor_04 communication error can_error_timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 68536 km
Date: 2025.10.28
Time: 17:52:54
16776989 - Databus
[RDK_02 communication error can_error_timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:13
16776978 - Databus
[LH_EPS_01 communication error can_error_timeout]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 253
Mileage: 68536 km
Date: 2025.10.28
Time: 15:56:47
16777072 - Databus
[WBA_03 communication error can_error_timeout]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 253
Mileage: 68536 km
Date: 2025.10.28
Time: 15:55:27
12858137 - Databus
U1122 00 [00001000] - Implausible Message
[LH_EPS_01 implausible signal]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 16:09:03
12858157 - Databus
[WBA_03 implausible signal]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 16:01:45
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4M1 907 468 A HW: 4M1 907 468 A
Component: Gateway H13 4079
Revision: 3B030052 Serial number: 5243B02B415A28 Dataset Number: 8W0909515E 0037
Coding: 0301000100000F4029000000005900124C1000000000000001 00000000000000
GVL: 01503C0000000000400C08000000C800000800000000000000 00000000000000
ASAM Dataset: EV_GatewCONTIAU736 002040
ROD: EV_GatewCONTIAU736_002_AU49.rod
VCID: 3530FD70F5CBA5626D5-8061
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 4M0 951 523 HW: 4M0 951 523
Component: J453 MFL H06 0002
Serial number: 20151115230102 00082
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 8S0 915 181 HW: 8S0 915 181
Component: J367-BDMHella H10 9052
Serial number: 6042588103
6 Faults Found:
66578 - FlexRay Databus; Branch 2
U11B0 00 [00001000] - Malfunction
[FlexRay_Data_Bus_Defect_Branch_2]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 16
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 16:01:36
131602 - Power Steering Control Module
U101D 00 [00001000] - No Communication
[Timeout_Node_0x12_DiagAdress_44_EPS]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 189
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 15:56:49
131603 - No Communication with ABS Brake Control Module
U0121 00 [00001000] - -
[Timeout_Node_0x13_DiagAdress_03_ESP]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 253
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:13
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [00001000] - -
[Timeout_Node_0x76_DiagAdress_01_Motor_MLBevo]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 253
Mileage: 68536 km
Date: 2025.10.28
Time: 17:52:57
131703 - No Communication with Transmission Control Module
U0101 00 [00001000] - -
[Timeout_Node_0x77_DiagAdress_02_Getriebe_DL382]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 254
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 15:55:29
8526353 - Generator
P1B00 00 [00001000] - Mechanical Malfunction
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:53:24
Generator voltage: 11.9 V
Battery voltage: 12.073 V
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 8W0 959 393 G HW: 8W0 959 393
Component: TSG FS 005 0052
Serial number: 0000172819909 Dataset Number: 8W0909872C 0021
Coding: 00101A204100008000001082
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
VCID: 4CC6B8948641C4AA22B-8019
2 Faults Found:
524339 - Databus
[Message Motor_14 missing]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:53:07
524421 - Databus
[Message ESP_21 missing]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:15
Address 44: Steering Assist (J500) Labels:| 8W0-909-144-V1.clb
Part No SW: 8W0 909 144 J HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0411
Dataset Number: 8W0909852R 0044
Coding: 09000380008000
Shop #: WSC 43848 005 1048576
ASAM Dataset: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
VCID: 44D690B4AE110CEAEAB-8011
7 Faults Found:
17664 - Databus
[KFC_ESP_22_SNA]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 23
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 15:55:26
Expanded ambient data 1-Engine running: Engine_Running_Stable
Expanded ambient data 1-Supply voltage: 0.00 V
Expanded ambient data 1-Temperature: -70 °C
Expanded ambient data 1-System status: 5
Expanded ambient data 1: 00
Expanded ambient data 1-driving_direction: 0
Expanded ambient data 1-KFA: 0
Expanded ambient data 1-KFC: 69
Expanded ambient data 1-Ready_To_Drive_Bit: 0
Expanded ambient data 1-StartStop Info: 0
Expanded ambient data 1-Steering_Angle_Calculated: 0 °
Expanded ambient data 1-Steering_Angle_Calculated_Sign: 0
Expanded ambient data 1-Steering_torque: 0.10 Nm
Expanded ambient data 1-Steering_Torque_Sign: 0
Expanded ambient data 15-MsgStateFifo_Byte0: 00 00 00 00
Expanded ambient data 15-MsgStateFifo_Byte1: 00 00 00 00
Expanded ambient data 15-MsgStateFifo_Byte2: 00 00 00 00
Expanded ambient data 15-MsgStateFifo_Byte3: 00 00 00 00
Expanded ambient data 15-NumOfMsgCntFaults: 00
Expanded ambient data 15-NumOfMsgCrcFaults_2: 00
Expanded ambient data 15-NumOfMsgNoFaults_3: 00
Expanded ambient data 15-NumOfMsgTimoFaults_1: 00
24832 - Databus
[KFC_DIAGNOSE_01_TIMO]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 252
Expanded ambient data 1-KFC: 97
Expanded ambient data 1-Steering_Angle_Calculated: 5 °
Expanded ambient data 1-Steering_Angle_Calculated_Sign: 1
Expanded ambient data 15-MsgStateFifo_Byte0: A2 82 00 00
Expanded ambient data 15-MsgStateFifo_Byte1: FF FF FF FF
Expanded ambient data 15-MsgStateFifo_Byte2: FF FF FF FF
Expanded ambient data 15-MsgStateFifo_Byte3: FF FF FF FF
Expanded ambient data 15-NumOfMsgTimoFaults_1: 04
20480 - FlexRay Databus
U1031 00 [00001000] - No Synchronization
[KFC_SYNC_LOSS]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 252
Expanded ambient data 1-KFC: 80
Expanded ambient data 14-KFA_FAST_RESET: 0
Expanded ambient data 14-KFC_FAST_RESET: 0
Expanded ambient data 14-Register_seg_flag: 0
Expanded ambient data 14-Rom_ram_ecc_adr_1: 0
Expanded ambient data 14-Rom_ram_ecc_eipc: 0
Expanded ambient data 14-Switched_voltage_terminal_30_unfiltered: 11.84 V
Expanded ambient data 14-Voltage_terminal_30_unfiltered: 12.02 V
10496 - Function Restricted due to Insufficient Voltage
U1400 00 [00001000] - -
[KFC_UCU_RED]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:52:51
Expanded ambient data 1-KFC: 41
Expanded ambient data 14-Switched_voltage_terminal_30_unfiltered: 8.78 V
Expanded ambient data 14-Voltage_terminal_30_unfiltered: 8.97 V
32512 - Databus
[KFC_MOTOR_12_TIMO]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:52:51
Expanded ambient data 1-KFC: 127
Expanded ambient data 15-MsgStateFifo_Byte0: AA AA AA AA
Expanded ambient data 15-MsgStateFifo_Byte1: AA AA AA AA
Expanded ambient data 15-MsgStateFifo_Byte2: AA AA AA 0A
Expanded ambient data 15-MsgStateFifo_Byte3: 80 02 02 80
Expanded ambient data 15-NumOfMsgTimoFaults_1: 2E
29440 - Databus
[KFC_ESP_21_TIMO]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:10
Expanded ambient data 1-KFC: 115
Expanded ambient data 15-MsgStateFifo_Byte1: AA 2A 00 00
Expanded ambient data 15-NumOfMsgTimoFaults_1: 17
27392 - Databus
[KFC_ESP_03_TIMO]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:10
Expanded ambient data 1-KFC: 107
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 CC HW: 8W0 907 064 C
Component: BCM2 MLBevo 015 0344
Dataset Number: 8W0909501C 0036
Coding: 013400000F100000630180000E00000031024000004B00502F 0400000104803F001F0001000000
ASAM Dataset: EV_BCM2HellaAU736 012013
ROD: EV_BCM2HellaAU736_012_AU49.rod
VCID: 7F5CDF588777AF32F79-802B
Anti-theft alarm system sensor:
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY152661XB9
Alarm horn:
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0312
Serial number: 00000000000033961613
Rear lid opener control module:
Subsystem 3 - Part No SW: 3AA 962 243 F HW: 3AA 962 243 F
Component: GEB.F.Heckoef H16 0816
Serial number: 94040139
5 Faults Found:
65573 - Databus
U1121 00 [00001001] - Missing Message
[Transmission control module: Getriebe_11: no signal/communication]
Freeze Frame:
Fault Priority: 6
Reset counter: 212
Mileage: 68536 km
Date: 2025.10.28
Time: 15:55:27
Supply voltages-Terminal 30 power supply: 14.294 V
Supply voltages-Supply voltage Terminal 30 - 2: 14.267 V
Supply voltages-Supply voltage Terminal 30 - 3: 14.334 V
general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
general_additional_freeze_frame-coprocessor_spi_status: 00000000
general_additional_freeze_frame-dataflash_status: 00000000
general_additional_freeze_frame-interior_temperature: -50.0 °C
general_additional_freeze_frame-Operating_Status: 00000000 00000000
general_additional_freeze_frame-production_mode: not active
general_additional_freeze_frame-reset_cause: 00000000
general_additional_freeze_frame-Reset_counter: 0
general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
general_additional_freeze_frame-subnetwork_status: 00000000 00000000
general_additional_freeze_frame-terminal_control_intern_status: 1B 02 CA 90 00 E0
general_additional_freeze_frame-Transport_Mode: not active
general_additional_freeze_frame-Vehicle speed: 0.00 km/h
can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
65603 - Databus
[Engine control module: Motor_12: no signal/no communication]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:52:55
Supply voltages-Terminal 30 power supply: 12.229 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.160 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.242 V
general_additional_freeze_frame-terminal_control_intern_status: 1B 01 0A 10 00 E0
65732 - Databus
[Engine control module: Motor_14: no signal/no communication]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 253
Mileage: 68536 km
Date: 2025.10.28
Time: 17:52:55
Supply voltages-Supply voltage Terminal 30 - 2: 12.147 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.215 V
65605 - Databus
[Brake control module: ESP_21: no signal/communication]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 253
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:10
Supply voltages-Terminal 30 power supply: 12.038 V
Supply voltages-Supply voltage Terminal 30 - 2: 11.957 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.011 V
general_additional_freeze_frame-terminal_control_intern_status: 1B 02 02 90 00 E0
65729 - Databus
[Brake control module: ESP_05: no signal/communication]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 253
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:10
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 8W0 959 392 A HW: 8W0 959 392
Component: TSG BFS 005 0039
Serial number: 0000174549250 Dataset Number: 8W0909873C 0021
Coding: 00101A204100008000001080
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
VCID: 45D08DB0A52B35E2FD5-8011
2 Faults Found:
524339 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:53:07
524421 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:15
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-STD2.clb
Part No SW: 8W0 035 824 HW: 8W0 035 824
Component: MU-S--ER 520 0621
Serial number: Dataset Number: 8W0909545G 0021
Coding: 01940100FF0A000013220001001A00002F0001C40170010002
ASAM Dataset: EV_MUStd6C3DELP 001013
ROD: EV_MUStd6C3DELP_AU37.rod
VCID: 75B03D70B54BE562AD5-8021
Multimedia display unit 1:
Subsystem 1 - Part No SW: 8W0 919 604 HW: 8W0 919 604
Component: AU49x_DU_STD H40 0008
Serial number: AUZ8Z9FBG008Q6
Multimedia system control head:
Subsystem 2 - Part No SW: 8W0 919 614 M HW: 8W0 919 614 M
Component: ControlUnit_B H22 0134
Serial number: C1000019091500020003
5 Faults Found:
6702 - Databus
[ESP: no communication]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:15
Voltage terminal 30: 12.1 V
Network diagnosis-Status: Enabled
6708 - Databus
[Engine: no communication]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:53:11
6919 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_timeout: heartbeat]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:15
7175 - Function Restricted due to Missing Message(s)
[Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:18
BAP-BAP_Function_ID: 02
7228 - Function Restricted due to Missing Message(s)
[Efficiency assist (0x3C) - function restriction due to communication error - BapErr_retry not successful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:53:11
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 E HW: 8W1 713 041 E
Component: GSM-LL H07 0068
Revision: 0L0D5012 Serial number: 20151110002152
ASAM Dataset: EV_GSMWaehlZFAU736 001013
ROD: EV_GSMWaehlZFAU736.rod
3 Faults Found:
24691 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 15:55:27
Voltage terminal 30: 14.2 V
Selec. range display: spec. val.: Malfunction
Selector lever position: Basic setting X
Standard_FreezeFrame_Extended_Temperature_CAN: 9C
Standard_FreezeFrame_Extended_Temperature_Celsius: 28.0 °C
System run time: 254 s
24696 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:54:11
Voltage terminal 30: 12.0 V
Selec. range display: spec. val.: P
Standard_FreezeFrame_Extended_Temperature_CAN: A3
Standard_FreezeFrame_Extended_Temperature_Celsius: 31.5 °C
33174 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 252
Mileage: 68536 km
Date: 2025.10.28
Time: 17:52:55
Voltage terminal 30: 2918.3 V
Standard_FreezeFrame_Extended_Temperature_CAN: FF
Standard_FreezeFrame_Extended_Temperature_Celsius: 77.5 °C
System run time: 255 s
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 8W0 959 395 A HW: 8W0 959 395
Component: TSG HFS 005 0039
Serial number: 0000175048768 Dataset Number: 8W0909897C 0021
Coding: 000018200000008000001080
ASAM Dataset: EV_DCU2RearDriveMAXHCONT 001005
ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
VCID: 48CE84849239288A063-801D
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 005 0039
Serial number: 0000175048279 Dataset Number: 8W0909896C 0021
ASAM Dataset: EV_DCU2RearPasseMAXHCONT 001005
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
End----------(Elapsed Time: 01:43, VBatt start/end: 12.4V/12.4V)-----------
------------------------------81 Faults Found------------------------------
Old Nov 4, 2025 | 05:04 PM
SMac770's Avatar
Community Builder
Community Influencer
That has to be the least equipped B9 A4 I've ever seen a scan of.
Network failure. So you had water or rodent intrusion and have wiring damage?
Voltage failure won't help you any either, through it appears you're recharged now.
If you just clear all codes, does the car function or not?
Old Nov 4, 2025 | 05:12 PM
oneisis15's Avatar
The codes appear after the vehicle has traveled a long distance and then continue to appear. Once the car has cooled down, everything works normally.
Old Nov 4, 2025 | 07:09 PM
SMac770's Avatar
Community Builder
Oh, the dreaded intermittent communication error scenario. Not sure what B9 owners have worked out regarding that manner of problem.
8526353 - Generator
That's something easy enough to validate, as you are getting errors logged with less than desirable system voltage. In VCDS, you should be able to find the generator commanded voltage under 19-gateway adv. measuring values when the engine is running. Do you measure that commanded voltage across the jump start posts? Do you measure that commanded voltage across the battery posts? But for all I know, that error occurred when the engine died because the ECM went offline, causing all the comms errors. You need to monitor your scan log more daily and relate the timestamps of the errors to what was going on at that time, maybe that'll give you a lead regarding under what scenario the codes are appearing. Take for example the 81-gear shift errors. I mean, wth with that date. What real world going on do those timestamps correlate to.
tubbycustard
A6 (C8 Platform) Discussion
Nov 12, 2024 06:33 AM
deabionni
A7
Feb 14, 2024 09:02 AM
Hobbes29
Audi A5 / S5 / RS5 (B9)
May 12, 2022 03:13 PM
Jonohio
Nov 12, 2019 06:08 PM
Velour
Jun 29, 2019 02:07 AM
