Which oil extractor?
Yesterday, in the middle of changing my oil and filter, my oil extractor pump stopped working. Usually, I just pump the handle 20-30 times to create a vacuum, and it sucks the oil out through the car's dipstick tube. But now, I have to keep pumping it -- removing just a little oil with every stroke.
Well, there was no way I was going to get under the car and drain the rest of the oil from the crankcase. So, 1,726 pumps later, the oil was removed.
Now, I'm looking to buy a new extractor. I notice there are basically two types: The manual vacuum suction pumps, and electrically-operated pumps. Does one have any major benefit over the other? I would imagine that the electric one would be way faster. But would a manual one be more reliable? I also use these to remove oil from my lawn mower and snowblower, so an electric one would have to be hooked up to my car.
Which one do you guys use?
I got a cheap plastic on off Amazon.
However why don't you fix the one you have? It should be easy to find the leak. Put a repair on it. The repair will be on the outside and since it draws a vacuum it will be strong. Superglue/epoxy for a hole. Or maybe it's an seal/o-ring.
I have the Bavarian Autosport version, sold by ECS Search SiteSearch oil extractor - B8800001 - Fluid Extractor - Bavarian Autosport (ecstuning.com) and elsewhere as part# PA-1011A. I like this model because it's hand pump or pneumatic operation and I have a compressor. Easiest oil changes ever!
I bought a West Marine one since I was able to pick it up locally (and on sale). Looks nearly identical to the Schwaben model. I've had it for 2 years with no issues.
https://www.westmarine.com/buy/west-...23?recordNum=1
