SS Pedal Caps
#61
There's a torx screw under a plastic cap on the foot rest (dead pedal). Pry that up with a tool, remove the screw. Be careful in that area, the fuse box is under the rest. Install is the reverse procedure.
#62
Im fine with haveing the torx screw driving my problem is prying off the cap that hides the screw any tips?
#63
1 Post
There is a post up a bit of someone trying to remove a clutch pedal, but there was no answer/follow-up. Maybe thats the one he was looking at?
#68
I think you need to get the narrow part of the rubber flange on first, then press the cap on the pedals. Trick being, get the flange all the way on (using spudger tool, screw driver, fingernails, etc) It involved putting the cap on so that the flange began fitting on to the back of the pedal, then working it on, all the way around the pedal.
At least that's what I did on my automatic transmission pedals,
