TPMS??
Old Jul 21, 2016 | 09:16 AM
Z06jerry's Avatar
Default TPMS??
Does the 2017 A4 (B9) use pressure sensors inside the tires??
Old Jul 21, 2016 | 09:42 AM
uberwgn's Avatar
Super Moderator
No. In-wheel sensors were done away with on most models beginning 2010 (in the USA).
BTW: rubber valve stems = no sensor in wheel
Old Jul 21, 2016 | 03:34 PM
adg44's Avatar
25 Year Member
Top Answer: 1
You'll only see direct TPMS on some RS models and the R8.
Old Jul 21, 2016 | 03:42 PM
Strife1013's Avatar
How are they measured now?
Old Jul 21, 2016 | 04:35 PM
uberwgn's Avatar
Super Moderator
Blaze:
https://www.audiworld.com/forums/q5-.../#post24782945
Old Jul 21, 2016 | 05:45 PM
adg44's Avatar
25 Year Member
Top Answer: 1
Wheel speed sensors. It is a flat tire warning.
Old Jul 21, 2016 | 06:05 PM
snagitseven's Avatar
Super Moderator
Also the A8 and S8.
Indirect TPMS works with the ABS and wheel rotation. No wheel sensor transmitters are needed (no expensive wheel sensor transmitters to be replaced as batteries wear out or for a second set of wheels).
Tire Tech Information - Tire Pressure Monitoring Systems (Direct vs. Indirect)
Old Jul 22, 2016 | 06:11 AM
adg44's Avatar
25 Year Member
Top Answer: 1
Originally Posted by snagitseven
Also the A8 and S8.
Negative to the A8.
Yes to the S8 plus which is essentially an RS model.
648GIII
S6 / RS6 (C7 Platform) Discussion
Apr 8, 2015 12:59 PM
KPSII
Mar 22, 2015 03:02 PM
parkrog
Jan 3, 2015 10:10 AM
GGroves
Q5/SQ5 MKI (8R) Discussion
28
Jan 23, 2014 06:33 PM
masonL
A7
14
Sep 28, 2011 08:43 PM
