VCDS Coding Help
Old Nov 30, 2017 | 04:51 PM
Quattrp's Avatar
Default VCDS Coding Help
Canadian 2017 A4 Techniq
I am trying to make some changes with a Ross-Tech HEX-V2 cable, but I am coming across obstacles for every change I am attempting.
1. Comfort turn signal: Change from 3 to 4 flashes
  • I have read to access 09 - Central Electronics --> Adaptations --> Channel 31 --> Change from 3 to 4.
  • However I am not getting the same drop down menu to select a channel as shown in this video at 25s https://www.youtube.com/watch?v=qJHezq06PUE&feature=youtu.be&t=25. Instead I get a screen that looks like this, and under the drop down menu I cannot find anything pertaining to the comfort turn signal.
2. Change parking camera deactivation speed
  • Instructions say to access 10 - Park/Steer Assist, however when I try to access it, an error pops up saying that it failed communication.
  • The module does not show up when I do an AutoScan, so I tried enabling it through module 19 (checked the tickbox next to module 10), but I still get the same error when trying to access it.
  • I have heard there may be issues with this module if the parking sensors are installed by the dealership, but I believe mine are factory installed as I have the option to adjust the sensor settings in the MMI.
3. Enabling Active Lane Assist
  • Just trying to follow instructions from this thread, but I can't even access the A5 module by manually typing it in. I get an error, of which I cannot remember what it says but it was not very enlightening (Can't be accessed, not found?)
Anyone able to help me with this issues?
Old Dec 1, 2017 | 03:05 PM
securityguy's Avatar
Get an OBD11...much easier and very cheap.
Old Dec 1, 2017 | 11:20 PM
audi8k's Avatar
I think the problem is that OP is trying instructions that are not valid for his car (at least point 1 & 2). The module 10 disappeared already in A4 B8 facelift. The B9 has even more differences.
gwagnerli
Q5/SQ5 MKII Discussion
Sep 28, 2017 06:44 AM
snagitseven
A4 (B8 Platform) Discussion
Oct 11, 2009 10:34 PM
3pt8 turbo
VAG-COM Discussion
Jan 31, 2008 03:36 AM
JoeO
21
Jun 13, 2004 08:27 PM
JoeO
VAG-COM Discussion
Jun 12, 2004 01:14 AM
