What's your favorite OBD Eleven change?
#151
Just found out my MMI version 1178 is not compatible with the app for VIM, darn!
Using OBD11 apps, I got easy entry and CD ripping to work. Nice!
Also, I found the adaptation for adjusting air con's auto fan speed. I often find the automatic fan speed setting too high (and loud). This adaptation seems to work nicely in bringing the speed down. I initially did -2 which was too aggressive and I ended up making it -1. Hopefully others find this helpful.
Adaptation
Control unit: 08 Air Conditioning
Name: Offset of fresh air blower speed
Values:
Old value: Default
New value: -2
I also attempted to fix the stupid 360 camera not sticking as default problem with the following, but sadly it didn't work. Anyone with better luck let me know!
Adaptation
Control unit: 09 Central Electrics
Name: Visual display for park assist
Values:
Old value: OPS display
New value: with OPS 360°
Adaptation
Values:
Old value: Default
New value: -2
Adaptation
Values:
#152
My favorite tweaks
- Traffic sign recognition (kufatec)
- welcome lights (walk up to car and leaving home lights activate before touching the car)
- Double beep for unlock, no beeps for lock
- ROW Air conditioning (more efficient and lower fan speeds than NAR spec)
- Dimmer virtual cockpit
- EU parking lights
- 4 blinks for turn signals
- Dimming DRL turn signals (subtle wink)
- Disabled side markers
- Autobahn/highway lights (headlights turn on at speeds above 130kph)
- Kessy comfort windows (touch and hold door lock sensor to close everything)
#153
details?
- EU parking lights
#156
Does anyone have the long coding for getting rid of the drl wink? I have an a5 and we only have the option to turn them on along with the Rear lights via the app. I know that the a4 has the option to turn on only the drl and set the brightness as well. So I figured I could use the same coding.
#158
https://docs.google.com/document/d/1jYl_MGIqijOyyeeeTI4fOQ02mfaN6W70vDmG4MjDUXM/mobilebasic#h.khbp8dvjfis6
STI2Audi (08-18-2019)
#159
Where are you guys getting your OBDEleven devices from? I’ve been waiting for months for the OBDEleven Pro to be available and its always out of stock. Even emailed them several times and they say a few months.
#160
