Footwell lights not working
After years between Audis, I'm back in the fold.
Have a new-to-me 2003 A4 Cabriolet 3.0 FWD with a few issues I'm trying to sort out.
1. None of the footwell lights work, nor the glove box light. Door lights and front reading lights work OK. Checked fuse F2 and fuse is fine.
2. Fuel door locking/not working and seems that previous owner at some point may have disconnected wiring.
I have a VAGCOM so can do some looking.
Any suggestions appreciated.
2. The Fuel door on my mine does not lock either...there is no latch or cable on mine, so check yours for actuator cable.
Door Courtesy Projector Lamps
Rear Underseat Footwell Assembly
My son uses the Audi all the time so in the course of a year I noticed (4) lights did not work and found all open filaments, you can see the telltale signs of molten metal coating the bulb glass. I also noticed the courtesy lights are sequenced so you have to manually unlock the passenger side button and it resets the cabin light & window bump sequence so when driver unlocks door the passenger side courtesy side lights properly. Complicated like the convertible top sequence.
Still having this problem
Filaments are fine, fuse is fine, fuse connections are fine. door lights work, none of the glove box nor footwell lights work. Any suggestions?
Still unresolved so bumping up.
Fuses are fine, Door switches are fine. Tested a few bulbs for continuity and they were fine.
Rexall
Audi Original "S" Cars
01-08-2008 08:42 PM
Pekboy
10-23-2007 02:32 PM
Mr. Z
9
02-17-2006 10:33 PM
neverfollow01
01-22-2006 01:26 PM
