LEDS! Reverse, Interior, License Plate - Free Shipping/Lifetime Warranty/Error Free
#21
Audiworld Basic Sponsor
All of our LEDs are tested to 100% work in your car to be bright and work without error! See the difference vs random LEDs:
www.deAutoLED.com
www.deAutoLED.com
w:http://deAutoKey.com
-Error Free LEDs for your Audi (interior & exterior)
f: https://www.facebook.com/deAutoKey
i: http://instagram.com/deAutoLED
#22
Trunk LED strip 48 LEDs
-no wiring
-plug and play
-this fits directly into OEM housing - wires are custom made to work
-includes 3m tape (optional velcro)
LISTING:
Universal 48 LED Flexible Strip for your Trunk [Fits all Car Models] | deAutoKey
Available in white or red!
Attachment 105148
Attachment 105149
-no wiring
-plug and play
LISTING:
Attachment 105148
Attachment 105149
#23
Amazing customer feedback!
Thank you
For anyone interested I just picked up some led reverse light bulbs and led fog lights from deAutoLed for by 09 a5. I have no errors on either and they’re both super bright. Links and pictures are provided.
I know it’s hard to find error free reverse leds but these truly are plug and play, no resistors or coding necessary. Same for the led fogs.
194/921 Error Free Bright Reverse LED Fits:Audi A3/S3/RS3/SQ5/Q5 + Many More | deAutoKey
LED Headlight/Fog CREE LED Bulb with Ballast - 9000 total lumens | deAutoKey
#24
Don't miss out - pick up a set for yourself and see the difference:
LED Headlight or Fog Bulb Kit - Error Free - Plug & Play | deAutoLED
More light
Error Free
Plug & Play
Won't cause blinding glare
NO radio interference
Shines past your headlights and helps more during bad weather, cornering, and on darker roads!
#25
We ship daily with a tracking # from the US - we provide customer service 24/7 - our LEDs are tested and made to work in your car!
www.deAutoLED.com
Support@deAutoLED.com
FB group for support/chilling with customers like yourself:
https://www.facebook.com/groups/deAutoLED/
www.deAutoLED.com
#26
White/Yellow/Halogen/Strobe/Flash plug and play fogs:
Dual Color LED Fog [1 bulb 2 colors] Choose between a Clean White & Hyper 3000k Yellow at anytime | deAutoLED
-Plug and play
-Error free in most cars. Some might need extra resistance - we sell a new design that DOES NOT require you to attach it to metal. It is compact and easy to install - simply plug into OEM adapter and our LEDs (100% plug and play NO splicing design)
-Easy to switch between each color – simply turn OEM fog switch off/on - normal cycle: White - yellow - halogen - flash/strobe
-BRIGHT – this is not just a novelty bulb
-COLOR MATCH - these match our LEDs/HIDs in 5500K White mode
-HYPER YELLOW - these are a true hyper yellow mode you normally see with yellow lamin-x covering the lens **this is NOT a cover around a bulb or a cover on your lens - this is brand new LEDs that are a super hyper 3K yellow**
-SAFE – more light on the sides and down the road when dark or in bad weather conditions
-The Hyper Strobe / Flash – this does not simply "flash" but has a strobe/flash pattern like an emergency vehicle - you can choose between 4 different modes - video of mode 1:
https://www.youtube.com/watch?v=T-fex4DUPSg
3 colors:
-Super Hyper 3000K Yellow that many like for bad weather: Rain, snow, fog
-Clean White 5500k that matches our LED & HID Headlights
-Halogen 4300k that matches OEM
Video cycling quickly through colors AND different strobe/flash features:
https://www.youtube.com/watch?v=bQG0gRKGFk0
INFO:
-THESE ARE BRIGHT! You might have seen the novelty fog LEDs that can turn yellow/white on amazon and ebay by the thousand that don't provide much useful light, trigger errors, die quickly, or simply don't work correctly. Our new model fixes every issue you might've seen and simply works.
-These produce MORE LUMENS than many standalone single color white fog LEDs on the market
-Not only are these great for safety, daily use on dark roads and bad weather this will amaze at any car show and you will have your friend asking how did you do that and where can I get those anytime you use these fogs!
*Please note these ARE error free but in strobe/flash mode they can trigger an error in some car models – errors WILL clear once you go back to a solid color.
Attachment 104952
Attachment 104953
UPDATED FAQ
Is there a lifetime warranty?
YES! As always this comes with a True Lifetime Warranty!
Will your fogs keep changing colors if you use them as cornering lights?
The answer is no as this only changes by turning your fog switch on/off. If you are using your fogs as cornering lights it will always be the default color of white.
How does this work with the coming home feature?
This works just like OEM. It will always be the default color of white.
What if I have the yellow feature on and turn off my car; will it then go into the next color when I turn it back on?
The LEDs will always revert back to the default color of white. Then simply turn the fog on/off for your desired color: yellow/halogen or strobe/flash mode.
Can these turn 360 degrees?
Yes, these are a fully adjustable design so you can turn these 360 for the best beam angle.
Are these as bright as your single color de360 fogs?
While not as bright lumen wise it comes very close - many people that have switched to our single color white to our dual color yellow/white LED fog kit have not noticed any difference in visibility. As we said this is NOT a novelty yellow/white you normally see. This is meant to be used to help with your visibility.
Can you bypass the strobe feature?
Yes, this works when you turn the fogs on/off quickly. If your next mode will be strobe simply shut off the fogs for a few seconds and then turn it back on and it will go back to the default white.
Attachment 105060
Attachment 105061
Attachment 105062
Attachment 105063
Some more fun shots - in the rain:
Attachment 104954
White / the super hyper yellow - this will be a hyper lamin-x yellow without the cover!
Attachment 104955
Attachment 104956
And switch back to clean white:
Attachment 104957
-Plug and play
3 colors:
INFO:
Attachment 104952
Attachment 104953
UPDATED FAQ
Attachment 105060
Attachment 105061
Attachment 105062
Attachment 105063
Attachment 104954
Attachment 104955
Attachment 104956
Attachment 104957
deAutoLED.com
A4 (B7 Platform) Discussion
85
03-05-2024 01:59 AM
deAutoLED.com
Audi A3 / S3 / RS 3
75
11-10-2023 11:00 PM
deAutoLED.com
77
09-20-2021 08:33 PM
deAutoLED.com
Audi A3 / S3 / RS 3 MKII
107
09-02-2021 08:53 AM
deAutoLED.com
10-24-2016 09:55 PM
