2014 Audi A6 C7 - Sound Unavailable Issue
2014 Audi A6 C7 3.0 TFSI Quattro with Bose sound system
I've thoroughly read over 50 posts related to this issue, but found no solution. If anyone can help, would be much appreciated.
XM, FM and AM seem to be tuning to all the channels and displaying channel information. CD seems to be playing. Bluetooth is able to connect. Memory Card seems to load tracks. Navigation system working properly.
However, no sound from speakers for any of these systems. Get "currently unavailable" when I try to adjust the volume. Voice control from steering wheel not functioning at all.
This issue started 2 weeks ago, while driving at local speed of 30 MPH, using iPhone on Bluetooth, sound cut off without any warning. Didn't hit any bump, no rain, nothing sporadic. No sound since then.
Had one brief moment of sound returned, but lost again immediately 10 seconds later. Wife has been driving car to and from work so plenty of time given for the issue to resolve itself, but no luck yet.
- Performed MMI reset using "three button press". No effect after reset.
- Checked all fuses in left/right cockpit and right side trunk. All pass visual check and multi meter check.
- Checked connectors on Bose Amp and Digital Sound Unit in the trunk. No visual corrosion or breakage. Optical cord emitting red light for both of these systems. Amp heats up when audio is attempted to be played (Amp getting power?).
- Poured gallons of water near closed sunroof. Checked for wetness in Amp/Sound Unit area in trunk immediately and every half an hour for 3 hours. No wetness present. No signs of water leakage
- Tried running "Optical Bus Diagnostics" in VCDS and received "cannot reach system".
- Ran auto-scan with VCDS and received the below.
Code:
VIN: WAUFGAFC1EN032606 License Plate: Mileage: 79980km-49697mi Repair Order: Chassis Type: FC-AU57 (4G0) Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 3C 42 44 46 47 52 53 55 56 5F 62 6C 72 8F 90 VIN: WAUFGAFC1EN032606 Mileage: 79980km-49697miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 3B-Sensor Elect. -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: Cannot be reached 0100 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 8F-Pretens. Frt Left -- Status: OK 0000 90-Pretens. Frt Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CTUA) Labels: None Part No SW: 4G0 907 551 J HW: 4G0 907 551 A Component: 3.0l V6 TFSIH07 0004 Revision: --H07--- Coding: 0A2A0032052601060000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_ECM30TFS0214G0907551J 001004 ROD: EV_ECM30TFS0214G0907551J.rod VCID: 303A1866DAAC9FB7EBA-8064 No fault code found. Readiness: 1110 1101 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb Part No SW: 4G1 927 158 A HW: 0BK 927 156 AM Component: 0BK 30TFSIUSA H16 1006 Revision: --H16--- Coding: 000002 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_TCMAL551211 002022 ROD: EV_TCMAL551211_002_AU48.rod VCID: 2D040112CD9EF25FC0C-8078 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb Part No SW: 4G0 907 379 L HW: 4G0 907 379 L Component: ESP PREMIUM H09 0450 Revision: -------- Serial number: -------------- Coding: 44A7970122E5E9805B00 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_ESPPremiAU57X 004039 ROD: EV_ESPPremiAU57X_004_AU57.rod VCID: 3A2E3A4E0CD055E755E-806E No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 4H0 907 064 DR HW: 4H0 907 064 DR Component: BCM2 2.0 H35 0510 Revision: 00002001 Coding: 0DA82046000000000000 Shop #: WSC 02391 785 00200 VCID: 7CA2FC5646E4ABD7072-8028 Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C Component: J764 ELV MLB H40 0046 Serial number: 2313000118739010 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:* None Part No SW: 4G0 820 043 AH HW: 4G0 820 043 AH Component: KLIMA 2 ZONEN H11 0091 Serial number: 06071300110145 Coding: 6681201849 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AirCondiBasisUDS 004001 ROD: EV_AirCondiBasisUDS_004.rod VCID: 6594B932D5EE0A1FC8C-8030 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb Part No SW: 4H0 907 063 CG HW: 4H0 907 063 Component: BCM1 2.0 H12 0130 Revision: 11012002 Serial number: 00000001750010 Coding: 0600A01106349FE08100088380003908CF9CD208A6090221000004406000 Shop #: WSC 02391 785 00200 VCID: 6FB8DB1A0792C04FB20-803A Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB Component: WWS57X 130628 H36 0080 Serial number: 130702220340 Coding: 0045F7 Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB Component: G397_RLFS H06 0002 Serial number: 21496790 Coding: 02006D Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D Component: E1 - LDS H07 0044 Serial number: 04 07 2013 00001511 Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A Component: USHL4.2 H30 0030 Serial number: 0000002274555R6S0Y02 Subsystem 5 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A Component: Humidity_Sens H03 0002 Serial number: 1CB848B6000000000001 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG Component: PARKHILFE ACC H01 0083 Revision: 11001001 Serial number: 61031319600275 Coding: A8C305 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_EPHVA18AU57X0000 004009 ROD: EV_EPHVA18AU57X0000_003.rod VCID: 71BCDD621126D6BFA44-8024 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 4H0-959-655.clb Part No SW: 4G0 959 655 A HW: 4G0 959 655 A Component: Airbag10.43 H33 0033 Revision: -------- Serial number: 003D80037W0N Coding: 303234373131303030314A55304C34473053 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AirbaAU10BPAAU64X 001014 ROD: EV_AirbaAU10BPAAU64X_AU57.rod VCID: 3330176A2BBAA4AF968-8066 Seat occupied recognition: Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B Component: BF-Gewichtss. H10 0046 Serial number: 6940000Y130000V5T40/ Crash sensor for side airbag: driver side: Serial number: 3575HRB401A50GM089V9 Crash sensor for side airbag: front passenger side: Serial number: 3585HRB400K50HLE5HEL Crash sensor for side airbag: rear: driver side: Serial number: 3515JRB401250JHQNH2F Crash sensor for side airbag: rear: passenger side: Serial number: 3525JRB400K50KB499M4 Crash sensor for front airbag: driver side: Serial number: 3554VRB400E50KB4FP4G Crash sensor for front airbag: front passenger side: Serial number: 3564VRB400E50KB4D0SE No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb Part No SW: 4H0 953 568 H HW: 4H0 953 568 H Component: Lenks.Modul H04 0005 Revision: -------- Serial number: 90372MG4001CV Coding: 000414 Shop #: WSC 02391 785 00200 VCID: 382A2046325C47F7A3A-806C Subsystem 1 - Part No SW: 4G0 951 528 F HW: 4G0 951 528 F Component: E221 - MFL H09 0010 Serial number: 06 06 2013 C1086429 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb Part No SW: 4G8 920 984 K HW: 4G8 920 984 K Component: TBenUsa H80 0618 Revision: 30460230 Serial number: 658100713596020 Coding: 03EF09040B41D705020000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RBD4K 004048 ROD: EV_RBD4K.rod VCID: 3E26365E10F879C7696-806A No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:* None Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC Component: J533--Gateway H12 0037 Revision: -------- Serial number: 00000001012265 Coding: 00CD073000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_GatewPkoUDS 001018 ROD: EV_GatewPkoUDS_001.rod VCID: 71BCDD621126D6BFA44-8024 Battery Monitoring Control Module: Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181 Component: J367-BDMHella H03 8041 Serial number: 2211200903 Voltage stabilizer: No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None Part No SW: 4G8 959 760 HW: 4G8 959 760 Component: MEM-FS H03 0154 Revision: AA000000 Serial number: 00000066815025 Coding: 00581B0000006001000001010101102030303232203232 Shop #: WSC 02391 785 00200 VCID: 77A8E37A7FC2888F6A0-8022 No fault code found. ------------------------------------------------------------------------------- Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb Part No SW: 4G0 907 637 K HW: 4G0 907 637 F Component: SARA 6D H02 0056 Revision: -------- Serial number: EJ1BPA82045Z27 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_SARA2 005012 ROD: EV_SARA2.rod VCID: 36362E7E38C8B187B16-8062 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change Labels: Redir Fail! Part No SW: 4G0 907 566 D HW: 4G0 907 566 Component: J769 SWA MasterH03 0060 Revision: 00H03000 Serial number: 6PZ 010 287-03 Coding: 0000001 Shop #: WSC 02391 785 00200 VCID: 303A1866D62C9FB7EBA-8064 Subsystem 1 - Part No: 4G0 907 568 D Component: J770 SWA Slave H03 0060 Subsystem 2 - Serial number: 6PZ 010 287-23 Subsystem 3 - Serial number: 5F09.07.1300H03000AMS15909ÿ Subsystem 4 - Serial number: S15909ÿ No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: None Part No SW: 4G8 959 793 J HW: 4G8 959 793 G Component: TSG FA H03 0507 Revision: -------- Serial number: -------------- Coding: 011F17005E00628002000012 Shop #: WSC 02391 785 00200 VCID: 47C853BA4FA2380FDA0-8012 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb Part No SW: 4G0 909 144 L HW: 4G0 909 144 G Component: RCEPS H38 0010 Revision: 00001000 Serial number: 0008656675 Coding: 101000010000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RCEPS 009008 ROD: EV_RCEPS_009.rod VCID: 323E126ED4A0ADA79DE-8066 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb Part No SW: 4H0 907 064 DR HW: 4H0 907 064 DR Component: BCM2 2.0 H35 0510 Revision: 00002001 Serial number: 0311051301 Coding: 0106063A00FA418582B0080402070E470000000000000000000000000000 Shop #: WSC 02391 785 00200 VCID: 7CA2FC5646E4ABD7072-8028 Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719 Component: GTO BF H01 0080 Serial number: 00000000000000163682 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C Component: J245 PS40.039 H01 0008 Serial number: WOO22808868 Coding: 101F00 Subsystem 4 - Part No SW: 3AA 962 243 B HW: 3AA 962 243 B Component: GEB.F.Heckoef H16 0810 Serial number: 93039814 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Cannot be reached ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: None Part No SW: 4G8 959 792 J HW: 4G8 959 792 G Component: TSG BF H03 0507 Revision: -------- Serial number: -------------- Coding: 011F17005E00628002000002 Shop #: WSC 02391 785 00200 VCID: 46D65EBE48A82107216-8012 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (----) Labels: 4H0-907-801.clb Part No SW: 4H0 907 801 G HW: 4H0 907 801 A Component: EPB-4 H03 0014 Revision: -------- Serial number: 00000000752340 ASAM Dataset: EV_ParkiBrake 001028 ROD: EV_ParkiBrake_AU57.rod VCID: 2C020C16F684FB57D72-8078 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb Part No SW: 4H0 907 357 B HW: 4H0 907 357 B Component: ....LWR12.... H02 0010 Serial number: 130711-0002-024 Coding: 1221A6101002A500 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_HeadlRegulBasic 005001 ROD: EV_HeadlRegulBasic.rod VCID: 2D040112CD9EF25FC0C-8078 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 5F: Information Electr. Labels: VCID: 55F489F28C0E9A9F58C-FFFE ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: None Part No SW: 4G8 959 795 J HW: 4G8 959 795 G Component: TSG HL H03 0507 Revision: -------- Serial number: -------------- Coding: 010F17004000628002000002 Shop #: WSC 02391 785 00200 VCID: 49CC558259B6CE7FCC4-801C No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 4H0-907-441.clb Part No SW: 4G0 907 441 B HW: 4H0 907 441 Component: SG Rueckfahrkamera 0061 Revision: --H07--- Serial number: 525 PA8J36G3T4 Coding: 1080004 Shop #: WSC 02391 785 00200 VCID: 2616FE3EE4E8C107016-8072 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: None Part No SW: 4G8 959 795 J HW: 4G8 959 795 G Component: TSG HR H03 0507 Revision: -------- Serial number: -------------- Coding: 010F17004000628002000002 Shop #: WSC 02391 785 00200 VCID: 49CC558259B6CE7FCC4-801C No fault code found. ------------------------------------------------------------------------------- Address 8F: Pretens. Frt Left (J854) Labels:. 4H0-980-94x-RGS.clb Part No SW: 4H0 980 945 B HW: 4H0 980 945 C Component: RGS-VL H13 0080 Coding: 0006E008031F0300070308014244CA010000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RGS_L 002004 ROD: EV_RGS_L.rod VCID: 313C1D62D1A696BFE44-8064 No fault code found. ------------------------------------------------------------------------------- Address 90: Pretens. Frt Right (J855) Labels:. 4H0-980-94x-RGS.clb Part No SW: 4H0 980 946 B HW: 4H0 980 946 C Component: RGS-VR H13 0080 Coding: 0006E008031F0300070308014244CA010000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RGS_R 002004 ROD: EV_RGS_R.rod VCID: 323E126ED4A0ADA79DE-8066 No fault code found. End----------(Elapsed Time: 02:16, VBatt start/end: 13.3V/13.3V)-----------
Just a stab in the dark. Since it happened while using bluetooth, have you tried deleting the bluetooth settings in the mmi? Maybe the system is hung somehow, thinking it is still in call mode via bluetooth. (I know a complete wild guess.)
The 5F module is the central "brain" of the entertainment system. It's possible that module is the culprit and needs to be replaced. Before going down that path though, I would try resetting all of the settings to the defaults in the MMI and start over including deleting your phone BT profile.
I've tried deleting the Bluetooth settings, along with all other settings in MMI and then resetting the MMI. No luck.
I also tried unplugging battery for an hour, but no luck with that either.
I didn't drive the car last week. Today I turned in car and sound was working as normal, but then went out in about 5 minutes.
I'm wondering if the actual sound package/radio went bad or if there is some bad grounding/wiring.
does anyone know how to to test the sound system for faults?
I had similar issue with my A6. it would mostly occur in cold weather below like 35 degrees. it'd not be there. then after driving for a bit, if I stopped for gas and shut car off it'd be ok when start back up. it eventually gave out and I had to have the unit replaced. i had to replace the center console as well as the unit in the trunk to restore back to functionality. it's not an inexpensive venture either.
no water or any other damage. it just expired I guess.
the guy that works on my Audi is a Sr. tech that works for Audi dealer, but he does work on the side. labor and parts rate much less, and he knows the cars well.
Probably a long shot but maybe there is a short in a speaker or connector that's tripping overload protection in the output amp, assuming it has protection. Try systematically disconnecting speakers and test it.
I opened the amp/digital sound package unit and don't see any visible damage to the circuit. Is it possible that the unit is damaged, but it doesn't show any signs?
