A6 Active Lane Assist Retrofit
#212
@1loveaudi
under vcds or odb11
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 933 B HW: 4G8 920 933 B
Component: TDieRdwAcc H80 0618
Revision: 30460230 Serial number: 658280613596049
Coding: 138F11024F4500080B0000
Shop #: WSC 06765 128 28888
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K.rod
VCID: 2F744A576721F0C565-807A
No fault code found.
under vcds or odb11
ROD: EV_RBD4K.rod
#213
So I have tried to rotate the video cable and it didn't helped. I get error video cable not connected or something like that. I have checked through my vcds scan and only component that using SARA is sensor Electronic on address 3B. There is no coding available there, but basic settings is available but I don't know what it does.
#214
#215
@1loveaudi
under vcds or odb11
ROD: EV_RBD4K.rod
under vcds or odb11
ROD: EV_RBD4K.rod
#217
Hi All,
I have successfully retrofitted Active Lane Assist in my 2015 A6 4G, well it works but the 5F menus do not. For a facelift car I have used the following 5F adaptations which bring up a menu of Audi Lane Assist with one sub menu of Steering Vibration Soft/Medium/Stong. I cannot make any changes using the menu. Also the menu keeps disappearing or going grey when driving. I have missing messages errors on 85 module (image processing).
According to the manual I should get Audi Active Lane Assist with two sub menus (Steering Input, early/late and Vibration on/off). Clearly this points to incorrect adaptations on the 5F.
The adaptation changes available for all the lane assistant and departure warning I have made are as below. I have fiddled with the ones for lane_assistant but this seems enable what I would call side assist. I have both on my A8 but that is not using MIB2 5F and just has green menu. I cannot find any other options that relate to Active Lane Assist.
Guidance much appreciated
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant - not activated
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer - not activated
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off -not activated
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high - not activated
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill - not activated
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning - activated
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaim er - not activated
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off - not activated
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold _high - activated
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill - not activated
Plus
ENG122229-ENG117740-Car_Function_List_BAP.......LDW_HCA_0x19 : activate
ENG122229-ENG117741-Car_Function_List_BAP.......LDW_HCA_0x19_msg_bus : Terminal 15
Latest Scan is
Sunday,23,June,2019,16:10:23:55272
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.0.4 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WAUZZZ4G8FN068483 License Plate:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 28 3B 42 44 46 52 53 55 5F 62
69 6C 6D 72 85 8E AC
VIN: WAUZZZ4G8FN068483 Mileage: 108775km-67589miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0110
19-CAN Gateway -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
8E-Image Processing -- Status: Malfunction 0010
AC-Reductant Control -- Status: OK 0000
Address 01: Engine (J623-CRTD) Labels:. 059-907-401-V2.clb
Part No SW: 4G2 907 401 B HW: 4G2 907 401
Component: 3.0TDI EDC17 H33 0001
Revision: 92H33---
Coding: 12254012052601030000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TDI0114G2907401B 001001
ROD: EV_ECM30TDI0114G2907311C.rod
VCID: 244720EF2F0C176FD3-8070
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G0 927 166 C HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H03 0007
Revision: --H03---
Coding: 100001
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021.rod
VCID: 2D51C5CB7CC6D6270C-8078
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q
Component: ESP9 Premium H01 0420
Revision: -------- Serial number: --------------
Coding: 17A69E41E86579829B00
ASAM Dataset: EV_ESP9BOSCHAU57X 003019
ROD: EV_ESP9BOSCHAU57X_003.rod
VCID: 3F8D8F83A6AA54B7AE-806A
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 FN HW: 4H0 907 064 EN
Component: BCM2 2.0 H36 0560
Revision: 00002001
Coding: 01B9704E000000000000
VCID: 7AFB3E97F508B19FD9-802E
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
Serial number: 3215000011387005
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Component: KLIMA 4 ZONEN H14 0112
Serial number: 12021500040194
Coding: 36A21178250000
ASAM Dataset: EV_AirCondiComfoUDS 003008
ROD: EV_AirCondiComfoUDS_003.rod
VCID: 63C563F36A825057EA-8036
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00001008344002
Coding: 0105001440349FE041014083000018000F9DE7082F08020100 000894E100130200400034030000
Shop #: WSC 53920 001 104857
VCID: 71E919BBA87EF2C768-8024
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 150111 H37 0080
Serial number: 150126014513
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 23730186
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 13 02 2015 00000883
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: F818C297000000000001
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P100390YW
Coding: 30333130313730323737554A305234473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 3B75FB93B2B2489782-806E
Crash sensor for side airbag: driver side:
Serial number: 3575HRB401G52UQM71L
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB405133PKM68CD
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB40145358SI2AU
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB40145358SP91-
Crash sensor for front airbag: driver side:
Serial number: 3554VRB400Q534069H6.
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB400M5340670PY
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372OBC00036
Coding: 0004F5
VCID: 387FE49F8B84638F6F-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Component: E221 - MFL H08 0010
Serial number: 06 01 2015 C0007902
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 985 L HW: 4G8 920 985 L
Component: TDieGb H08 0043
Revision: 04001037 Serial number: 658180215596026
Coding: 33A612000B552600010000
ROD: EV_RBD4K_AU57.rod
VCID: 408F8C7FDB542B4FD7-8014
2 Faults Found:
1048578 - No Basic Setting
B2010 00 [009] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 230
Mileage: 108745 km
Date: 2019.06.23
Time: 11:04:58
16776980 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 16
Mileage: 108753 km
Date: 2019.06.23
Time: 12:20:17
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4G8 907 468 HW: 4G8 907 468
Component: J533--Gateway H13 0075
Revision: -------- Serial number: 00000001729380
Coding: C0CD078118
ASAM Dataset: EV_GatewPkoUDS 001024
ROD: EV_GatewPkoUDS_001_AU57.rod
VCID: 75E12DABD416DEE7B4-8020
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 1900125603
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 1412100000000000044B
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 14021500040455
Coding: 22
ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
ROD: EV_ClimaContrUnitRearUDS_003.rod
VCID: 3D71F58BACA646A7BC-8068
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA8208ZJ6T
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3663EAA7899095FF7D-8062
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011C16015001620002080002
VCID: 479D9763F67A1C7716-8012
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0016426092
Coding: 101001010001
ASAM Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_009.rod
VCID: 3365D3B39AE280D75A-8066
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0360799116
Coding: 013B0622A0B93080C320090420010F47000000000000000000 0000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0507
VCID: 46839A67F170057FED-8012
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001368405
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_VW51.rod
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Part No SW: 4H4 907 357 D HW: 7P6 907 357 B
Component: MxB-ECU 001 0081
Coding: 04FE02202A130200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
Led Headlamp Powermodule Left:
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01F00
Led Headlamp Powermodule Right:
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E01F00
Matrix Headlamp Powermodule 1 Left:
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo li. H03 0031
Coding: E01F00
Matrix Headlamp Powermodule 1 Right:
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo re. H03 0031
Coding: E01F00
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 021 D HW: 4G1 035 021
Component: MU-H-LND-EU 041 0389
Serial number: A588B0F7505471
Coding: 017502010000000013111102000A00132F0006E7F1700100DF
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
VCID: 1B351B131272289762-804E
Data medium:
Subsystem 1 - Part No SW: V03 959 801 FD HW: -----------
Component: ECE 2017/2018 --- 0161
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9EY800PTF
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
Component: E380 BDT C7 H20 0250
Serial number: 90349OBD0006Q
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1012
1 Fault Found:
7961 - Control module
B2001 00 [008] - Incorrect software version
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 17
Mileage: 108771 km
Date: 2019.06.23
Time: 15:53:53
Voltage terminal 30: 14.5 V
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 D HW: 4G8 959 795
Component: TSG HL H03 0212
Coding: 01081C004001620000080002
Shop #: WSC 02312 785 00200
VCID: 43858373C2423057CA-8016
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4G8 907 383 B HW: 4G8 907 383 B
Component: Anhaenger H14 0113
Serial number: 0000454261
Coding: 0100000202000000
ASAM Dataset: EV_TrailFunctGener2Hella 001005
ROD: EV_TrailFunctGener2Hella_VW26.rod
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H04--- Serial number: 525 PA8J1XG2SO
Coding: 1030005
Shop #: WSC 98765 666 38384
VCID: 26433AE79130E57FCD-8072
1 Fault Found:
03006 - Back-up Camera System not calibrated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 230
Time Indication: 0
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0150
Revision: 14005001 Serial number: 030500754
Coding: 093205C010
ASAM Dataset: EV_HDSGAu572 001022
ROD: EV_HDSGAu571.rod
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0212
Shop #: WSC 28100 141 104456
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
Component: DPC-SG H27 0081
Revision: -------- Serial number: 262130025421000
Coding: 71160000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C57C8CF47DCDF2F1B-8078
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4H0 907 107 H HW: 4H0 907 107
Component: BV-SG H33 0090
Serial number: 005000621903157
Coding: 044239040111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
2 Faults Found:
0025 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 230
Mileage: 108745 km
Date: 2019.06.23
Time: 11:50:49
Outside air temperature: 18.5 ∞C
Voltage terminal 15: 11.6 V
Control Module temperature: 30.0 ∞C
0061 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 230
Mileage: 108745 km
Date: 2019.06.23
Time: 11:50:48
Address AC: Reductant Control (J880) Labels: 4G0-907-355.clb
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 150210145
ASAM Dataset: EV_RDCMA00100 008040
ROD: EV_RDCMA00100_008.rod
End-------------------------(Elapsed Time: 05:51)--------------------------
Plus
Latest Scan is
www.Ross-Tech.com
Revision: 92H33---
Revision: --H03---
Coding: 100001
Revision: 00002001
Coding: 0045F7
Coding: 02006D
Coding: 0004F5
2 Faults Found:
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 230
Mileage: 108745 km
Date: 2019.06.23
Time: 11:04:58
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 16
Mileage: 108753 km
Date: 2019.06.23
Time: 12:20:17
Coding: C0CD078118
Voltage stabilizer:
Coding: 22
ROD: EV_SARA2.rod
Coding: E01F00
Coding: E01F00
Coding: E01F00
Coding: E01F00
Data medium:
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 17
Mileage: 108771 km
Date: 2019.06.23
Time: 15:53:53
Coding: 1030005
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 230
Time Indication: 0
Coding: 093205C010
Coding: 71160000
ROD: EV_BC7.rod
2 Faults Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 230
Mileage: 108745 km
Date: 2019.06.23
Time: 11:50:49
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 230
Mileage: 108745 km
Date: 2019.06.23
Time: 11:50:48
#218
I’m dooing the same project, same car, a6 4g facelift mib2.
does your car have the 8E From the factory? Or retrofited? Mine does not, and i’m struggeling to figure out where the cables from the 8E goes. Mine does not have acc.
Any ideas?
Any ideas?
#219
Hi there, I can help you. Do you not have 8e which is the camera or 85 image processing. I had the 8e as the car had matrix lights but not the 85. I got all the cabling info from ElsaWin, do you have the wiring diagrams. If you don’t have 8e you will need, screen, camera and then calibration.
#220
I have the camera 85 up and running. Elsawin says there is cables to pins 3 and 29 in the abs. If i plug in the cables on the abs unit, it disables itself, and i get all error codes possible, due to missing nr 03. If i remove the wire, its all back to normal. So is elsawin wrong? Or is there a second solution? Did i do something wrong? Abs sw ends with Q
