aircon problem
Old Sep 26, 2019 | 12:23 PM
doc3695's Avatar
Default aircon problem
I have a 2014 A6 C7 thats blowing cold air from the drivers side but warm air from the passengers. I also hear a hissing sound from inside the dash or maybe from the firewall. I got the aircon regassed and the tech told me there were no leaks found and that the gas was very low. Everything worked fine for about 3 weeks but now it's worse than ever. The garage tested the system and said that it has lost some gas and pressure but they have no idea why. Any ideas?
Old Sep 26, 2019 | 06:36 PM
Bartenderfloyd's Avatar
Could be the blend door.
Old Sep 27, 2019 | 06:57 PM
back13a6's Avatar
When ever you have one side cooler than the other and that hissing noise from the dash the Freon is low in my experience as a service advisor. You have a leak somewhere. If they can't find it you need to get some dye put in the system and then should be able to track it once it starts leaking.
Old Sep 27, 2019 | 11:10 PM
doc3695's Avatar
Thanks for the reply. It did work great after the initial regas so a leak is likely but their machine is not picking one up
Batran1
Jun 14, 2016 05:23 PM
Batran1
Events Discussion
Jun 12, 2016 07:40 PM
leftright
Jul 4, 2003 01:03 PM
AudiTrio
Aug 11, 2002 09:56 PM
Slinky
May 5, 2002 05:58 AM
