Automatic engagement of emergency brake
Old Oct 4, 2012 | 12:27 PM
SA_Gator's Avatar
Default Automatic engagement of emergency brake
I just took delivery of my 2013 S6 yesterday (brilliant black, black sport seats, LED's, 20" wheels, side assist, black headliner, brushed aluminum) and I've noticed that every time I turn the ignition on the emergency brake is engaged (without me engaging it before turning the ignition off). It seems this is an automatic function and I've never noticed it on any of my prior Audis (and it's quite annoying). I've looked at the car settings and can't seem to find a way to disengage this feature. Anyone have any ideas?
Old Oct 4, 2012 | 12:41 PM
snagitseven's Avatar
Super Moderator
With 2013 A6/S6, you need to have your seat belt fastened. The brake will auto release as soon as you put it in drive or reverse and tap on the accelerator. You get used to it (and you should be wearing your seat belt anyway).
Old Oct 4, 2012 | 12:47 PM
GiantEli's Avatar
That isn't my experience. I have to manually undo the parking brake after every cold start.
SA said it was part of pre-sense.
Old Oct 4, 2012 | 12:56 PM
Super Moderator
He's incorrect. If it's not working, something is wrong with your car. Mine will auto disengage every time so long as my seat belt is fastened. Are you stepping on the gas? You'll feel it disengage after you give it a bit of torque. It jerks just a bit as it releases then the car keeps going as you give it more gas.
Old Oct 4, 2012 | 09:04 PM
KarKid's Avatar
Your SA is incorrect. If you put your seat belt on, put it in reverse, step on the gas, the E brake will release. I do this every morning without any failure. Try it!
Old Oct 5, 2012 | 06:17 AM
SA_Gator's Avatar
Default Thanks!
...and, of course, I always wear my seat belt!
bothfly
Q7 MK 1 Discussion
Feb 22, 2014 09:21 PM
ch7656
A4 allroad (B8 Platform) Discussion
Sep 14, 2013 11:50 AM
zerinS4
TT (Mk2) Discussion
15
Jun 11, 2007 08:13 AM
Hutan
Jun 19, 2006 12:24 PM
BigRonsAudi
Oct 20, 2002 07:39 PM
