Beware of Oil Consumption
#11
So a vehicle that has been maintained according to the manufacturer is good, but that may not not be good enough. The manufactures do not care because these problems only manifest themselves after the warranty has ended, after which they become the responsibility of the owner.
EDIT: Adding image of oil separator job.
#12
The oil separator with integrated PCV valve is the first thing I replaced because it blew the day I took delivery and the car started whistling and knocking. Whistling and knocking stopped after the replacement of the oil separator and PCV unit but that did not fix oil consumption.
#13
Try a compression test and if any cylinders are low then try to scope the cylinders for evidence of vertical scoring in the walls. If deep scoring is present then suspect long term stuck open injector causing oil consumption. If this is the issue then it’s already too late for the block.
JBenDavid782 (08-03-2023)
#14
What is your summarized warning?
The lengthy video and the lengthy link are supporting documentation for what your describing but I didn’t have the time to get to the end of any of it.
I have a C6 A6 3.0T CCAA at 90,000KM using premium fuel and full synthetic and zero oil consumption so far. I decarb’d intake and did a major service at 60K since it’s non MPI early North American 3.0T and check every 5K - 10K for stuck injector. I replace thermostat and PCV Oil Separator as a maintenance item to minimize carbon buildup and avoid failure. Injectors have been replaced twice, once on recall and once by me since one was caught early stuck open. I send in my spare set of injectors for professional cleaning so they are ready for next install if / when needed. It’s more headache than most owners want to be involved with but it’s the way I have found to keep this engine running properly for a long time.
#16
227,000 miles on my A7.
oil consumption yes, dead motor no. There is another poster on the A7 board with many more miles than mine.
For the most part these engines will last a very long time. Defects or owner negligence towards maintenance are the main causes towards premature death.
#17
90,000 km is what? 56,000 miles? Keep adding miles and come back after 100,000 miles or 160,000 km. Your engine is still too young for you to claim anything and yet you said you have replaced injectors twice and have replaced the oil separator as well. My advice is for people purchasing this car north of 60,000 miles or 100,000 km.
People, DON'T BUY!!! Lease and let go.
#18
My car was dealer maintained from start to finish yet the engine is failing. Same for a lot of people reporting this in this C7 forum and also in the Q7 MKII forum. Of course there are exceptions but a lot of people are reporting the same issues with cars still under warranty or barely outside of warranty. This can't be a coincidence.
We all love the brand but please let's not be fanatics defending the "undefendable".
#19
My recommendation along with hoist review inspection, diagnostic scans before and after test drives when buying used higher mileage is a compression test and some simple checks for leaking injectors. If a cylinder is low compression then walk away unless your looking for a project car and can buy it cheap.
The following 2 users liked this post by urs6_ma:
JBenDavid782 (08-03-2023),
keg97 (03-03-2024)
