Can I subsitute Rear bumper Cover: 4G5807067GRU for 4G5807067AGRU
Hi,
My 2013 Audi A6 was totaled in an accident. Among other things I need to replace the rear bumper. I'm trying to do as much of the repair myself as I can. It requires the following rear bumper
4G5807067AGRU: 2012-15, A6, W/O S-LINE PKG, w/reverse sensor, w/reverse sensor.
I was able to find the same bumper without the reverse sensor hole at a local junkyard. That model is 4G5807067GRU. I'm assuming these are identical bumpers except for the holes. Is it possible to drill the holes on my own. Overall I do not even care for the reverse sensor. I'm perfectly fine driving without it. I'm assuming both of the bumpers are identical except for the holes. I wanted to check if anyone had further information regarding this here.
4G5807067GRU: 2012-15, A6, W/O S-LINE PKG, w/o reverse sensor, w/o reverse sensor.
Thanks for your help.
You will probably find that the outlines of where the holes go are on the inside of the undrilled bumper and you can easily drill them yourseld. Suggest you do it before painting. Also I would suggest you refit the sensors otherwise you may get lots of annoying error beeps each time you select reverse
AudiNike12
04-10-2020 02:07 AM
bydecebalus
09-28-2009 02:24 PM
kasperl
03-06-2006 07:51 AM
