DK: multiple errors?
Old Jul 8, 2021 | 03:35 AM
dannibach's Avatar
Default DK: multiple errors?
Hi All,,
im having a few issues with my A6 from 2015 (avant)
OIne day multiple errors came up at once while i just starteds driving. (ABS, Parking brake, Airbag, TPMS , rear parking sensor and so on)
I can delete the erros with both VCDS and OBDeleven, but they come back.
if i leave them there the may or may not stay on for some time but mostly the errors on the dash dissapears and only the airbag light is on.
also the rear parking sensor complains when reversing.
Any experts in here that could give me a hand reading my vcds dump and help me get this sorted?
VCDS dump
Thursday,08,July,2021,13:20:32:21935
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64)
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WAUZZZ4G1FN080281 License Plate: CS29336
Mileage: 129069km-80199mi Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 3B 42 44 46 52 53 55 5F
62 69 6D 72 8F 90 AC
VIN: WAUZZZ4G1FN080281 Mileage: 129069km-80199miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
AC-Reductant Control -- Status: OK 0000
Address 01: Engine (J623-CTCC) Labels:. 059-907-401-V2.clb
Part No SW: 4G1 907 401 HW: 4G0 907 401 E
Component: 3.0TDI EDC17 H14 0005
Revision: 58H14---
Coding: 12254012053401030000
Shop #: WSC 67593 771 32928
ASAM Dataset: EV_ECM30TDI0114G1907401 001006
ROD: EV_ECM30TDI0114G0997401E.rod
VCID: 61C358BB701C0583AC-8034
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 4G1 927 153 L HW: 0CK 927 156 Q
Component: 0CK 30TDI RdW H01 0001
Revision: --H01--- Serial number: 0000000008
Coding: 100001
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL382021 002028
ROD: EV_TCMDL382021_AU49.rod
VCID: 336FE2F39A60C7130E-8066
MTF pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 H
Component: V553 MTFP HC4 0421
Serial number: S2AG75.109_02 11
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q
Component: ESP9 Premium H01 0420
Revision: -------- Serial number: --------------
Coding: 17A29E41E8457982BB00
Shop #: WSC 05296 002 1048576
ASAM Dataset: EV_ESP9BOSCHAU57X 003019
ROD: EV_ESP9BOSCHAU57X_003.rod
VCID: 3F87BEC3A6281373FA-806A
8 Faults Found:
124416 - Function Restriction due to Faults in Other Modules
U1113 00 [040] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 4
Mileage: 128537 km
Date: 2021.07.05
Time: 08:19:28
VzRef: 00
Bit Info 1: C0
Bit Info 2: 0F
Bit Info 3: 22
Bit Info 4: 1F
Uz: 91
Unlearning counter according OBD: 39
200448 - Function Restriction due to Faults in Other Modules
U1113 00 [040] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Mileage: 128634 km
Date: 2021.07.05
Time: 14:55:04
VzRef: 2F
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
Uz: B6
200192 - Function Restriction due to Implausible Message(s)
U1112 00 [040] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 128623 km
Date: 2021.07.05
Time: 14:33:39
VzRef: 24
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
Uz: B8
95232 - Rear Left Wheel Speed Sensor
C101C 07 [104] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
VzRef: 00
Bit Info 1: 00
Bit Info 2: 02
Bit Info 3: 20
Bit Info 4: 1F
Uz: A1
204032 - Rear Left Wheel Speed Sensor
C101C 01 [032] - Electrical Failure
Intermittent - Not Confirmed - Tested Since Memory Clear
102144 - Rear Left Wheel Speed Sensor
C101C 29 [096] - Signal Implausible
103168 - Rear Left Wheel Speed Sensor
105472 - Rear Left Wheel Speed Sensor
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 FN HW: 4H0 907 064 EN
Component: BCM2 2.0 H36 0560
Revision: 00002001
Coding: 01A9700E000000000000
VCID: 7AF10FD7F58AF65B8D-802E
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Component: KLIMA 4 ZONEN H14 0112
Serial number: 19031500042197
Coding: 36021178210000
ASAM Dataset: EV_AirCondiComfoUDS 003008
ROD: EV_AirCondiComfoUDS_003.rod
VCID: 63CF52B36A001793BE-8036
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00001030246702
Coding: 0105C014403C9FE0C181408300001800CF9CE7082E08020100 000894E101140200400024030000
Shop #: WSC 12345 123 61029
VCID: 71E328FBA8FCB5033C-8024
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 150228 H37 0080
Serial number: 150310050958
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 23816991
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 AL HW: 4G0 941 531 AL
Component: E1 - LDS H07 0044
Serial number: 10 03 2015 00001243
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 75788A97000000000001
1 Fault Found:
02070 - Rear Parking Aid Sensors
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 54
Mileage: 128922 km
Time Indication: 0
Date: 2021.07.06
Time: 16:54:05
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P1003RTMO
Coding: 30333130313730323731554A304C34473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 3B7FCAD3B2300F53D6-806E
Crash sensor for side airbag: driver side:
Serial number: 3575HRB406933RVKB9UD
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585HRB406333HNK78RP
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3515JRB400G5340ASH1U
Passenger side rear thorax airbag crash sensor:
Serial number: 3525JRB404T36RT860CS
Crash sensor for front airbag: driver side:
Serial number: 3554VRB40165362SB17V
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB40185362SDGKL
3 Faults Found:
1049351 - Databus
U1123 00 [008] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 94
Mileage: 128537 km
Date: 2021.07.05
Time: 08:19:32
1049605 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 94
Mileage: 128537 km
Date: 2021.07.05
Time: 08:19:49
9682162 - Multiple collision brake
B13BC F2 [136] - No function
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 128537 km
Date: 2021.07.05
Time: 08:19:43
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862OCI000MM
Coding: 000015
VCID: 3B7FCAD3BA300F53D6-806E
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Component: E221 - MFL H08 0010
Serial number: 28 02 2015 E0094966
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 933 Q HW: 4G8 920 933 Q
Component: TDieRdw H08 0043
Revision: 04001037 Serial number: 658170315596051
Coding: 03AF12000B41000C010000
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 3E79C3C7A1221A7BF1-806A
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4G8 907 468 HW: 4G8 907 468
Component: J533--Gateway H13 0075
Revision: -------- Serial number: 00000001772959
Coding: C0CD078118
ASAM Dataset: EV_GatewPkoUDS 001024
ROD: EV_GatewPkoUDS_001_AU57.rod
VCID: 75EB1CEBD4949923E0-8020
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 2330866003
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 150106000000000003A7
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 04018264747464545425363E00
VCID: 7CFD09CFFFBEC86B9F-8028
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 23031500041916
Coding: 20
ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
ROD: EV_ClimaContrUnitRearUDS_003.rod
VCID: 3D7BC4CBAC240163E8-8068
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720GDE03
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011F17014000628002080002
VCID: 4797A623F6F85BB342-8012
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 S HW: 4G0 909 144 G
Component: RCEPS H43 0012
Revision: 00001000 Serial number: 0005582725
Coding: 101000010001
ASAM Dataset: EV_RCEPS 009013
ROD: EV_RCEPS_009.rod
VCID: 3973D0DBB80C3D43C4-806C
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0363091588
Coding: 0100063820B93000C320090428010F47000000000000000000 0000000000
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0507
VCID: 4689AB27F1F242BBB9-8012
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001394931
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D5BF48B7C4491E358-8078
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Part No SW: 4H4 907 357 E HW: 7P6 907 357 B
Component: MxB-ECU 001 0100
Coding: 04FA02102A630200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
VCID: 346DE1EF9F6EC02B17-8060
Left LED Headlamp Power Output Stage 1:
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01E00
Right LED Headlamp Power Output Stage 1:
Subsystem 2 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7570
Coding: E01E00
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 4G1 035 043 P HW: 4G1 035 043
Component: MU-H-N-EU 041 0073
Serial number: A591C0F7510297
Coding: 01750201FF0A000013110001000A00002F0006E5F1700100DF
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
VCID: 2B5FFA9342509FD346-807E
Data carrier:
Subsystem 1 - Part No SW: V03 959 801 F HW: -----------
Component: ECE 2015/2016 --- 0122
Serial number: --------------------
Multimedia System 1:
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0006
Serial number: AUZ8Z9EY800S36
Multimedia system control head:
Subsystem 3 - Part No SW: 4G1 919 610 F HW: 4G1 919 610 F
Component: E380 BDT C7 H20 0250
Serial number: 90349TBC0000U
Compact disc data bank:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote --- 1010
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
Component: TSG HL H03 0507
Coding: 010F15004000628002080002
VCID: 4993A01BE0ECADC354-801C
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4G8 907 383 B HW: 4G8 907 383 B
Component: Anhaenger H14 0137
Revision: 7B001002 Serial number: 0372893852
Coding: 0100000202000000
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_TrailFunctGener2Hella 001005
ROD: EV_TrailFunctGener2Hella_VW26.rod
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0150
Revision: 14005001 Serial number: 074501862
Coding: 093205C011
ASAM Dataset: EV_HDSGAu572 001022
ROD: EV_HDSGAu571.rod
VCID: 3669DBE78912D23B29-8062
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0507
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Coding: 00060000031F030000030801424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 3163E8FB607CF5037C-8064
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 3261E7F7657ACE1B05-8066
Address AC: Reductant Control (J880) Labels: 4G0-907-355.clb
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 150500234
ASAM Dataset: EV_RDCMA00100 008040
ROD: EV_RDCMA00100.rod
End-------------------------(Elapsed Time: 05:12)--------------------------
Thanks
Danni
Old Jul 8, 2021 | 04:28 AM
John Simcox's Avatar
25 Year Member
The first point of atack when yiu get multiple seemingly unrelated errors like this is to look at the battery. The A6 is very susceptible to low battery voltage. I am assuming as yiur car is a 2015 then it is still on the original battery. If that is the case it is quite possible that the batteyr is starting to become less optimal, even though it is still working. I would suggest replacing the battery as the first step, after 6 years it won't do any harm to have a new battery, and see if that solves the problem.
Old Jul 8, 2021 | 05:43 AM
dannibach's Avatar
Hi
I changed the battery last week and I changed the abs sensor rear.left today.
I'm running a scan as I type this crossing fingers
Danni
Old Jan 31, 2023 | 02:46 AM
jonaskh91's Avatar
Default Multi error
Originally Posted by dannibach
Hi
Danni
did you solve your problem by changing the battery? I Got same issue with my Audi a6 C7
chocoheston
Audi 100 / A6 (C4 Platform)
18
Jan 15, 2009 06:55 PM
AndrewM (azdaspeed3)
Feedback
Feb 6, 2002 06:18 PM
S4_Obsessed
Feedback
Feb 3, 2002 10:59 PM
GuilTTy
Dec 12, 2001 07:14 AM
FT
Feb 29, 2000 08:50 PM
