EPC and Engine Light on my 2012 A6
Well, I've been waiting for the day when my A6 is out of warranty and something goes wrong. Yesterday was that day. With 60K miles on the car, I got an EPC light and engine light with very heavy engine vibration and little acceleration. Since it was a yellow light, I decided to limp it to my local Audi servicer instead of having it towed. I probably should have had it towed. After 1 day with the Audi techs, they don't know what's wrong. How can that be?? I said aren't there codes that tell you exactly whats wrong?? Just doesn't seem reasonable. I'll wait it out but I have a feeling I 'll be looking at a hefty bill. Coincidently enough, I had only driven 50 miles following the 55K servicing (yes, I was late) where the plugs are replaced. I can't but help it feel something they did caused this problem. No other issues before that except for an intermittent audible rattle sound during the first start of the day which only last a second while the engine comes up to speed. Will let you know what they find in case someone else ever has the same problem.
Sorry to hear that but be patient they should be able to figure it out and hopefully nothing serious, ie: expensive... Please do let us know when you find out what's actually wrong.
The noise you are hearing at cold start is the timing chain. The link below explains and provides the TSB. Shouldn't be causing a CEL. I have the noise too.
https://www.audiworld.com/forums/a7-...-tfsi-2900612/
FastLane '12 A6 Quattro Prestige 3.0T, Uni Stage 2+, Eurocode sways and bushing inserts, 20" RS6 Reps
Coincidently enough, I had only driven 50 miles following the 55K servicing where the plugs are replaced. I can't but help it feel something they did caused this problem.
The Audi 3.0L has some new technology that should also be added to the search of finding the root cause of the problem. The technicians have a procedure to follow. They tend to not share what they have done so far because the explanation would not be understood unless the owner knows the interconnectivity of the control systems.
Thanks Tenspeed. Thats exactly what I'm thinking and now after 2 full days with the Audi techs, they "claim" they still don't know what the issue is. I've asked them both days if they can confirm if all cylinders are firing or not, and they won't answer. They beat around the bush. Isn't that a simple question to answer after 2 days of diagnosing the problem? Shouldn't they be able to tell me if all cylinders are firing or not?
I agree with TenSpeed and think he's right on the nose. Get the full write-up of what they think is wrong then let us know. Chances are you can take the car to a different shop at half the cost. If the diagnosed problem is easy enough for a DIY, there may be a thread to help you take care of it at minimal cost. We just need the details of what they claimed to have found.
Personally, I like and prefer the option of having dealer diagnose my car. I then either fix it myself or pay trusted indy shop at half the cost.
Oh and if you wouldn't mind, could you please post the codes that came up when you get these?
Thank you.
Thank you.
