EPC light lit after attempting to pass
As I drove home, went to pass someone, engine bucked hard. I looked down and noticed the EPC light lit up, plus a message stating I could not exceed 4000 rpm. The red band on the tach started at 4k instead of the normal top end.
Pulled out the VCDS reader found
Oil Pressure Switch
P164B [036] - Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
There's more, but probably not relevant. I reset the fault code and see if it appears again. Due for 55k mile service in two days, will bring saved printout to them to check it out. And try to keep the engine rpm at a reasonable level should it happen again.
So my question is:
Does the Oil Pressure Switch fail so early on in the life of the engine? I don't know the history yet of these vehicles, just moved to this one after years of VW ownership. (Dieselgate forced my hand.....)
Oil Pressure Switch
Fault Priority: 2
Fault Frequency: 1
So my question is:
My Audi A6 2006 3.2L Quattro just had the Fuel filter and oil filter changed. Now she wont start when engine is warm/hot, and will DIE, like at a stop light. Could this be a Camshaft Speed Sensor issue?? Any help would be AWESOME!!! Thank you so much!
Your car is a C6, not a C7 so probably worth reposting your question on the C6 forum
Oil Pressure Switch
Fault Priority: 2
Fault Frequency: 1
So my question is:
Oil Pressure Switch
Fault Priority: 2
Fault Frequency: 1
So my question is:
My bad on not mentioning the engine. 3.0l V6 TFSIH07 0006
It was definitely a shock when it went into protection mode, the engine, like hitting a wall.
After resetting the fault last night, on the way home I wanted to see if it would repeat itself. Engine fully warmed up and I floored it. Well not quite, but did go well above 4k rpm, until it hit 5.4k rpm when the fault returned. This time no bucking felt, just a gradual slowdown as I immediately lifted off the accelerator. Reading the code once I returned home, again Oil Pressure Switch P164B.
I also notice the Battery Voltage being lower this time. Previously it read 12.898438 V, and this time it is 12.796875. Not much of a difference, but I did have a low battery alarm two days ago while reading codes for the first time. Could be a relation, perhaps not. Will know for sure on Saturday when Audi does the 55k mile service. I'll post a follow up.
Here's a thread about a S6 that getting the EPC light during WOT. Some people suspected low voltage among other things. The voltage at 12.9 and 12.8 at the battery is low for a running engine.
EPC light w/o power loss
