Fault code 4087- Help!
Fault code 4087- Help!- FIXED
Hello.
my car is having this error
A help from somebody who has gone through this would be much appreciated!
car is Audi A6 c7 3.0 TDI 245hp
thanks in advance!
FIXEDFIXED FIXED FIXED
FIXED.
after replacing timing belt, and repairing transmission, this error came up...
after some long searches through the car, the mechanics successfully found the error to be on the housing of the g28... it was full of some kind of liquid... got it cleaned up and replaced the sensor with new one... its all good now.
thanks in advance!
FIXED.
The answer can be pretty legit... changing it.
but, I have changed it, instaled a new one, but it was showing the same error.
it goes to 1000rpm constantly right around 10 seconds after starting engine.
and some bad noises can be heard in front of the car.
I must mention, it has new timing chain, a month ago.
What could it be?
What could it be?
VAG SCAN after visiting mechanics.
they only changed the sensor((if they did change the correct sensor)) and realized it had the same error...
so they put back the old one, and just put back all other stuff.
this is scan now with some other 3 faults
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Wednesday,18,October,2017,19:41:19:62939
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 20 22 28 34 36 3B
3C 42 44 46 47 52 53 55 56 5F 62 6D 72 82 84 85 88 89 8B 8E
8F 90
VIN: WAUZZZ4G6BN017364
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
22-AWD -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
82-Heads Up Display -- Status: OK 0000
84-Night Vision -- Status: Malfunction 0010
85-On Board Cam. -- Status: Malfunction 0010
88-Multicont. Seat Driver -- Status: OK 0000
89-Multicont. Seat Pass. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
8E-Image Processing -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
Address 01: Engine (J623-CDUC) Labels: Redir Fail!
Part No SW: 4G0 907 401 F HW: 4G0 907 401
Component: 3.0TDI EDC17 X37 0006
Revision: 53X37---
Coding: 0A254012046601020000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM30TDI0114G0907401F 001006
ROD: EV_ECM30TDI0114G0907401F.rod
VCID: 264310135912D62ECEF-8073
4 Faults Found:
5168 - Altitude Sensor / Boost Pressure Sensor
P1592 00 [101] - Implausible Correlation
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 178139 km
Date: 2000.00.00
Time: 00:00:00
4124 - Sensor Reference Voltage B
P0651 00 [167] - Open Circuit
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 178139 km
Date: 2017.10.18
Time: 19:31:11
2815 - Accelerator Position Sensor 2 (G185)
P2127 00 [167] - Signal too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 178139 km
Date: 2000.00.00
Time: 00:00:00
4087 - Engine Speed Sensor (G28)
P0322 00 [237] - No Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Mileage: 178136 km
Date: 2017.10.18
Time: 15:59:04
Readiness: 1 1 0 0 0
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 4G0 927 156 K HW: 0B5 927 156 F
Component: 0B5 30 TDIRdW H10 0014
Revision: --H10--- Serial number: 0000001309
Coding: 000001
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_TCMDL501 A02087
ROD: EV_TCMDL501.rod
VCID: 3467FA5B9FCEB4BE40B-8061
No fault code found.
Address 03: ABS Brakes (J104) Labels: 4G0-907-379.clb
Part No SW: 4G0 907 379 B HW: 4G0 907 379 B
Component: ESP PREMIUM H09 0190
Revision: -------- Serial number: --------------
Coding: 27B6C700E46DE300CB00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 003013
ROD: EV_ESPPremiAU57X.rod
VCID: 306FF64B6BD6889E243-8065
1 Fault Found:
0723 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 47
Mileage: 178037 km
Date: 2017.10.08
Time: 17:26:19
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 AP HW: 4H0 907 064 AP
Component: BCM2 2.0 H24 0217
Revision: 00002001
Coding: 01A83000000000000000
VCID: 77FD0D57C6389FA6A59-8022
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4G8 959 760 B HW: 4G8 959 760 B
Component: MEM-BFS H04 0153
Revision: AA000000 Serial number: 00001002338834
Coding: 0018320000006201000001010101112030303333283333
VCID: 3979CB6FB0AC49D693D-806C
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.clb
Part No SW: 4H0 907 063 G HW: 4H0 907 063
Component: BCM1 2.0 H12 0092
Revision: 11012002 Serial number: 00000000962811
Coding: 0907201109749FE2A981008380001800CF9CC2082E08010100 0108542F00
VCID: 2C57E23B4FFEEC7E18B-8079
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119
Component: WWS57X 110218 H32 0051
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 H HW: 4G0 941 531 H
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Coding: 110000
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Coding: 110000
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 F HW: 4H0 035 108
Component: DVDCAlpine H42 0200
Revision: AA001001
Coding: 010000
VCID: 2345090722202306A91-8076
Address 10: Park/Steer Assist (J791) Labels: 4H0-919-475-7X5.clb
Part No SW: 4H0 919 475 E HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0013
Revision: -------- Serial number: 56231104902363
Coding: 102B05
ASAM Dataset: EV_EPHVA2CAU57X0000 001004
ROD: EV_EPHVA2CAU57X0000.rod
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 4G0 907 561 HW: 4G0 907 561
Component: ACC3 H15 0160
Serial number: 00000000000000
Coding: 3E04010202
ASAM Dataset: EV_AdaptCruisContrAU57X 001003
ROD: EV_AdaptCruisContrAU57X.rod
VCID: E7DDDD171E988F26B59-80B2
3 Faults Found:
10240 - Sensor for Automatic Distance Control
C110B F0 [008] - Limited Visibility
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 87
Mileage: 178077 km
Date: 2017.10.09
Time: 11:45:22
82688 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 47
Mileage: 178037 km
Date: 2017.10.08
Time: 17:26:19
93440 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 87
Mileage: 178132 km
Date: 2017.10.18
Time: 14:12:58
Address 15: Airbags (J234) Labels: None
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG001RED7
Coding: 30323436313330303335554A304C34473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: 3663C05389B2A6AE7EF-8063
Crash sensor for side airbag; driver side:
Serial number: 3575HRB404R0G68UG13I
Crash sensor for side airbag; passenger side:
Serial number: 3585HRB404R0G68U192B
Crash sensor for side airbag; rear driver side:
Serial number: 3515JRB405709GGSFON3
Crash sensor for side airbag; rear passenger side:
Serial number: 3525JRB406109GGSM18B
Crash sensor for front airbag; driver side:
Serial number: 3554VRB404V6P1I8IHGJ
Crash sensor for front airbag; passenger side:
Serial number: 3564VRB40556ORG8D9A%
Address 16: Steering wheel (J527) Labels: None
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H03 0003
Revision: -------- Serial number: 90372KBQ0000Z
Coding: 0000FC
VCID: 377DCD5786B85FA6659-8062
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H07 0009
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 931 HW: 4G8 920 931
Component: TDieRdwAccNv H34 0309
Revision: 18100069 Serial number: 658290111593006
Coding: 138F0900DF050008000200
Shop #: WSC 34723 002 104857
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K.rod
VCID: EBD5A1270270AB46D11-80BE
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 C HW: 4G0 907 468 A
Component: J533--Gateway H08 0204
Revision: -------- Serial number: 00000000104415
Coding: 00CD077D00
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650685469
Voltage stabilizer:
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8K0 857 511 E HW: 8K0 857 511 A
Component: FLA H04 0004
Revision: AA001002
Coding: 04018264747464545425363E
VCID: 3365F94792C0B386591-8066
Address 22: AWD (J492) Labels: None
Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
Component: 4 Wheel Drive H11 0013
Serial number: 001802110001046
ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
ROD: EV_AllWheelDiffeQSPFR.rod
VCID: 275D1D175E18CF26F59-8072
Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
Part No SW: 4G0 919 158 D HW: 4G0 919 158 D
Component: KLIMA FOND H07 0056
Serial number: 25021100040261
Coding: 00
ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
ROD: EV_ClimaContrUnitRearUDS.rod
Address 34: Level Control (J197) Labels: None
Part No SW: 4G0 907 553 B HW: 4G0 907 553
Component: LUFE-DAEMPFER H17 0778
Coding: 008002
ASAM Dataset: EV_AirSuspe 003022
ROD: EV_AirSuspe_AU57.rod
VCID: 2A5BE4234D0AF24EEA7-807F
3 Faults Found:
455688 - Sensor for Ride-Height
C1048 07 [008] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 87
Mileage: 178132 km
Date: 2017.10.18
Time: 13:52:39
455690 - Sensor for Ride-Height
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Date: 2000.00.00
Time: 00:00:00
403200 - Function Shut-Off Active
C10C8 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 178132 km
Date: 2017.10.18
Time: 13:50:49
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H04 0153
Revision: AA000000 Serial number: 00001002338814
Coding: 0018330000016201000001010101112030303333203333
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 C HW: 4G0 907 637 C
Component: SARA 6D red H02 0004
Revision: -------- Serial number: EJ1BPA3E002B7V0
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA.rod
VCID: 2E53E83371E29E6E36F-807B
Address 3C: Lane Change Labels: None
Part No SW: 4G0 907 566 C HW: 4G0 907 566
Component: J769 SWA MasterH01 0020
Revision: 00H01000 Serial number: 6PZ 010 287-01
Coding: 0000101
VCID: 2F6DF537BEE897663D9-807A
Subsystem 1 - Part No: 4G0 907 568 C
Component: J770 SWA Slave H01 0020
Subsystem 2 - Serial number: 6PZ 010 287-21
Subsystem 3 - Serial number: 5F04.03.1100H010003CD20078ÿ
Subsystem 4 - Serial number: D20078ÿ
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 B HW: 4G8 959 793
Component: TSG FA H04 0210
Coding: 011F06205E00628202080003
Shop #: WSC 02312 785 00200
VCID: 3F8DA577AE8867E6AD9-806A
Address 44: Steering Assist (J500) Labels: None
Part No SW: 4G0 909 144 L HW: 4G0 909 144 F
Component: RCEPS H32 0010
Revision: 00001000 Serial number: 0027042383
Coding: 101101010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS.rod
VCID: 326BFC4365DABA8E527-8067
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0144902808
Coding: 0100062000B93480832008040C010000000000000000000000 0000000000
Address 47: Sound System (J525) Labels: None
Part No SW: 4G0 035 465 HW: 4G0 035 465
Component: BO G3 C7 H07 0120
Revision: 05S00000 Serial number: 0011419
VCID: E2CBCC03FDBAEA0E627-80B7
Subsystem 1 - Part No SW: 4G0 035 466 HW: 4G0 035 466
Component: BO C7 SLAVE H51 0100
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 C HW: 4G8 959 792 A
Component: TSG BF H04 0210
Coding: 011F06205E00628202080002
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000044929
ASAM Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_AU48.rod
1 Fault Found:
464128 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 47
Mileage: 178037 km
Date: 2017.10.08
Time: 17:26:18
Address 55: Xenon Range (J431) Labels: None
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0012
Serial number: 110228-0004-110
Coding: 11216F601002A300
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
VCID: 2C57E23B47FEEC7E18B-8079
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 053 J HW: 4G0 035 053
Component: Radio U Basic H52 0133
Revision: AB001007 Serial number: 050BP0B7544362
Coding: 010003010000000001
VCID: 2541171F2C14DD36C75-8070
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 670 P HW: 4G0 035 670
Component: H-BNT-EU H46 0939
Revision: -------- Serial number: 428CR0B7511019
Coding: 060100000003FDED7D148B3E00000003140001000000000000
Shop #: WSC 04399 002 104857
VCID: 306FF64B63D6889E243-8065
Subsystem 1 - Part No: 8R0 060 884 DF
Component: EUR 2016 2204
Subsystem 2 - Part No SW: 4F0 910 393 AH HW: 4F0 862 393 E
Component: BTHS H25 0750
Subsystem 3 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Subsystem 4 - Part No SW: 4G1 919 610 C HW: 4G1 919 612 L
Component: E380 BDT C7 H08 0204
Subsystem 5 - Part No: 8R0 060 961 A
Component: CD-Database 2712
2 Faults Found:
03175 - Invalid Data Set
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 20
Mileage: 177475 km
Time Indication: 0
Date: 2017.09.29
Time: 18:27:06
Freeze Frame:
Voltage: 12.00 V
03623 - Invalid Secruity/Release Code
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 20
Mileage: 177475 km
Time Indication: 0
Date: 2017.09.29
Time: 18:27:06
Freeze Frame:
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 C HW: 4G8 959 795 A
Component: TSG HL H03 0210
Coding: 010F04204000628202080002
VCID: 428BAC83DD7A0A0EC27-8017
Address 6D: Trunk Elect. (----) Labels: None
Part No SW: 4G5 959 107 HW: 4G5 959 107
Component: HDSG-Modul H01 0036
Revision: 13001001 Serial number: 046100229
Coding: 111104C000
ASAM Dataset: EV_HDSGAu571 001001
ROD: EV_HDSGAu571_AU57.rod
VCID: EFEDB53736685766FD9-80BA
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0210
Address 82: Heads Up Display (J898) Labels: 4G0-919-604.clb
Part No SW: 4G0 919 604 HW: 4G0 919 604
Component: HeadUpDisplay 016 0042
Revision: 00000000 Serial number: 00000000000000
Coding: D70000
ASAM Dataset: EV_HUDContiC7 001020
ROD: EV_HUDContiC7.rod
VCID: E8DFDE2B1386805EBC3-80BD
Address 84: Night Vision (J853) Labels: 4H0-907-547.clb
Part No SW: 4H0 907 547 E HW: 4H0 907 547
Component: NV-ECU-Gen1 H09 0026
Serial number: 0K84AE40026118
Coding: 1311
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
VCID: 3169F34F60DC81962BD-8064
1 Fault Found:
12306 - Video Cable for Night Vision System
B11E1 29 [009] - Signal Implausible
Freeze Frame:
Fault Priority: 4
Fault Frequency: 41
Reset counter: 47
Mileage: 178032 km
Date: 2017.10.08
Time: 15:55:50
Address 85: On Board Cam. (J852) Labels: None
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H24 0034
Revision: -------- Serial number: 262130025421000
Coding: EA060000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: E5C1D71FE4949D36875-80B0
1 Fault Found:
0708 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 178132 km
Date: 2017.10.18
Time: 14:12:56
Address 88: Multicont. Seat Driver (J873) Labels: None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00456842057401
Coding: 662FF2
ASAM Dataset: EV_IVBDriveSideFrnt 001003
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2F6DF53776E897663D9-807A
Address 89: Multicont. Seat Pass. (J872) Labels: None
Serial number: 00456842159802
Coding: 262FF2
ASAM Dataset: EV_IVBPasseSideFrnt 001003
Address 8B: Adaptive Cruise 2 (J428) Labels: None
Part No SW: 4G0 907 541 HW: 4G0 907 541
Coding: 3E04010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
ROD: EV_AdaptCruisContr2AU57X.rod
2 Faults Found:
12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 87
Mileage: 178110 km
Date: 2017.10.12
Time: 14:08:42
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 47
Mileage: 178037 km
Date: 2017.10.08
Time: 17:26:19
Address 8E: Image Processing (J851) Labels: 4G0-907-107.clb
Part No SW: 4G0 907 107 B HW: 4H0 907 107
Component: BV-SG H28 0034
Serial number: 000040182202117
Coding: 04C0BB1A1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 2541171F2414DD36C75-8070
1 Fault Found:
0091 - Function Limitation due to Missing Video Data
C1108 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 87
Mileage: 178132 km
Date: 2017.10.18
Time: 14:12:57
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 0066E608031F037E070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: F0EFB64B2B56489EE43-80A5
End ---------------------------------------------------------------------
8F 90
Revision: 53X37---
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 178139 km
Date: 2000.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 178139 km
Date: 2017.10.18
Time: 19:31:11
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 178139 km
Date: 2000.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Mileage: 178136 km
Date: 2017.10.18
Time: 15:59:04
Coding: 000001
1 Fault Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 47
Mileage: 178037 km
Date: 2017.10.08
Time: 17:26:19
Revision: 00002001
Cannot be reached
Coding: 0045F7
Coding: 02512B
Coding: 110000
Coding: 110000
Revision: AA001001
Coding: 010000
Coding: 102B05
Coding: 3E04010202
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 87
Mileage: 178077 km
Date: 2017.10.09
Time: 11:45:22
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 47
Mileage: 178037 km
Date: 2017.10.08
Time: 17:26:19
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 87
Mileage: 178132 km
Date: 2017.10.18
Time: 14:12:58
Coding: 0000FC
ROD: EV_RBD4K.rod
Coding: 00CD077D00
Voltage stabilizer:
Revision: AA001002
Coding: 00
Coding: 008002
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 87
Mileage: 178132 km
Date: 2017.10.18
Time: 13:52:39
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Date: 2000.00.00
Time: 00:00:00
C10C8 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 178132 km
Date: 2017.10.18
Time: 13:50:49
ROD: EV_SARA.rod
Coding: 0000101
ROD: EV_RCEPS.rod
1 Fault Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 47
Mileage: 178037 km
Date: 2017.10.08
Time: 17:26:18
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 20
Mileage: 177475 km
Time Indication: 0
Date: 2017.09.29
Time: 18:27:06
Freeze Frame:
Voltage: 12.00 V
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 20
Mileage: 177475 km
Time Indication: 0
Date: 2017.09.29
Time: 18:27:06
Freeze Frame:
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
Coding: 111104C000
Coding: D70000
Coding: 1311
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 41
Reset counter: 47
Mileage: 178032 km
Date: 2017.10.08
Time: 15:55:50
Coding: EA060000
1 Fault Found:
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 178132 km
Date: 2017.10.18
Time: 14:12:56
Coding: 662FF2
Coding: 262FF2
Coding: 3E04010202
2 Faults Found:
C1103 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 87
Mileage: 178110 km
Date: 2017.10.12
Time: 14:08:42
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 47
Mileage: 178037 km
Date: 2017.10.08
Time: 17:26:19
ROD: EV_BC7.rod
1 Fault Found:
C1108 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 87
Mileage: 178132 km
Date: 2017.10.18
Time: 14:12:57
ROD: EV_RGS_L.rod
ROD: EV_RGS_R.rod
A couple of advices
Not many has TDI on the other side of pond.
First, erase fault memory and see which ones come back after a couple of days driving.
Second, if you want some response, delete all no fault module stuffs from the log.
It doesn't add any value and takes long time to scroll and hard to see the faults.
P0322 in your original post is for camshaft sensor.
Which sensor did the mechanic replace?
The only fault from the engine is the first one on the photo, so the fault number 4087.
I just got some information on justanswer.com which I paid 31$ to contact an audi expert, he told me that the car must be driven at least 50 miles after replacing the sensor g28..
which he said its a sure thing and after that, try if theres any fault. And it supposed to be removed.
Awkward thing is that it says ‘no signal’ and when its no signal, the engine shouldnt start at all...
its just so confusing.
FIXED.
