Interior LED Kit + License Plate LEDs-Error Free-Lifetime Warranty-Free shipping
Audiworld Basic Sponsor
---------------------------------------------LEDs------For------Your-------Audi----------------------------------------------------------------
CHECK OUT OUR NEW AUDI SECTION ON OUR WEBSITE!!!!!
CLICK HERE for all Updated LEDs for your Audi Car - updated with new LEDs weekly!
Our LEDs are PLUG AND PLAY / ERROR FREE
Click here for all All C5 LEDs
**PLEASE NOTE** IF you do not see your model listed, contact us and we will work on SPECIAL PRICING to make you a custom set, if you help us test and review a NEW Audi LED Kit it will be FREE!!
Features of our LEDs:
-The lights will "fade out" when you turn off your car just like your current stock lights
-These will not stay on or “glow” after you shut off your car like other sets
-Crisp White color – No cheap blue or yellow tint
-Works with MFD (car controls)
-No Errors
-Lifetime Warranty
-No footwell spotting like other inferior LED sets
Interior LED Kits:
LEDs for Audi ? deAutoKey
License Plate LEDs:
Check out our Universal LED bulbs For Audi License Plates:
Universal License Plate LEDs Super Bright / Error Free Fits many VW and Audi Models ? deAutoKey
-Compatible with-
Audi MKII TT
Audi B5 A4
Audi B5 S4
Audi A3 8P
Audi A4 B6 B7
And our Complete LED Housing Audi License Plates:
LED License Plate Housings Crisp White-Error Free-Plug and play Fits: Many Audi Models ? deAutoKey
-Compatible with-
A3/S3 O4-09
A3 Cabriolet 08-09
B6 A4/S4 01-05
B7 A4/S4 05-08
A6/C6 05-09
S6 05-09
D3 A8/S8 03-07
Q7 07-09
RS4 Avant Quattro 06-08
RS4 Carbriolet 06-08
RS6 Avant 08-09
Before & After:
Same bulbs for sale are being used in cars below:
*NEW*LED FOOTWELLS:
New & the first!!
Footwell Option for Audi models equipped with OEM LED footwells!
Choose from Crisp White / Red or Blue!!
New LED Footwells for Audi models that are equipped with OEM LED Footwells ? deAutoKey
If you have non-LED Footwells, please follow link below:
2pc 6 LED Wafer Footwell set in Crisp White/Red/Blue fits: VW, Audi, all cars ? deAutoKey
*NEW*TRUNK LED Strip - Brightest option ever:
Get the brightest LED for your trunk with no hassle at our low introductory price. [THIS FITS ALL CAR MODELS]
To purchase:
Universal 48 LED Flexible Strip for your Trunk [Fits all Car Models] ? deAutoKey
We did the research, and created the best and brightest LED for your trunk, our 48 LED Strip simply lines your trunk, with either 3m tape or velcro which are both included.
This is the best solution for a dark trunk, easily installs and hides:
-Plug & Play
-Error Free
-48 Bright White LEDs (Also comes in red)
-Enough LEDs to light up your entire trunk but short enough to fit any trunk, can install vertically or horizontally.
-Long wire, that is an all stealthy black which allows for an easier clean install, this wire is long enough to place anywhere in your trunk
-Strong 3M tape & Velcro so you can install on any hard surface or trunk lining (please use a blow dryer to heat up glue and cold metal, this will activate the glue)
-Resistor which allows for the light to stay on and not dim if your dome lights shut off while trunk is open. This feature is a must have, it allows for a bright continuous light at all times.
-Trunk LED will not stay dimly lit when your car is off.
-Comes with 3 adapters: Wedge, Adjustable Festoon, and Bayonet, this will fit every trunk adapter on the market.
Actual LED strip measures: 31 inches – this length will fit all trunks, can install vertically or horizontally.
Black Wire measures: 52 inches – please note- excess wire simply tucks into your trunk’s housing/lining so you will not have any leftover in your trunk.
Includes:
1 LED strip with strong 3M tape attached
3 Adapters (Wedge/festoon/bayonet)
3 Pieces of velcro
And we can modify any kit with red, blue or white LEDs at not extra cost:
Bright trunk LED is also included:
-No Errors
-Lifetime Warranty
Interior LED Kits:
License Plate LEDs:
-Compatible with-
Audi MKII TT
Audi B5 A4
Audi B5 S4
Audi A3 8P
Audi A4 B6 B7
-Compatible with-
A3/S3 O4-09
A3 Cabriolet 08-09
B6 A4/S4 01-05
B7 A4/S4 05-08
A6/C6 05-09
S6 05-09
D3 A8/S8 03-07
Q7 07-09
RS6 Avant 08-09
Before & After:
*NEW*LED FOOTWELLS:
New & the first!!
To purchase:
-Plug & Play
-Error Free
Includes:
3 Pieces of velcro
w:http://deAutoKey.com
-Error Free LEDs for your Audi (interior & exterior)
f: https://www.facebook.com/deAutoKey
i: http://instagram.com/deAutoLED
amazing review/diy:
I bought these from deAutoKey.
PWY24W Front Turn Signals Error Free - Available in White or Amber fits: Audi A3 ? deAutoKey
These LED's work as puddle lights or footwell lights.
194 10pc CREE LED Reverse LED Fits:Audi A3/S3/RS3 + Many More ? deAutoKey
Reverse Lights
Pry off this trim piece towards the rear of the car, there are little alignment tabs that go straight back. There are also two little tabs that hook onto the actual tail light.
Remove the two Torx screws pictured. Make sure they don’t fall down behind the bumper, because that would be a pain in the *** to retrieve them.
Pull the tail light housing straight out.
The reverse light bulb is the top one in the picture. Twist it until it comes loose and pulls out, then replace the stock bulb with the new LED.
Reverse the steps to reinstall.
Puddle lights
Pry the housings from the edge pointing towards the front of the car until it pops out.
Unplug it from the wiring.
There are two clips holding the black part of the housing to the clear diffuser. Use a small flathead to pry it upwards until it comes apart.
I have no pictures of me swapping out the stock bulb, but it is pretty self explanatory when you see it. Not difficult at all.
With these LED’s, I had to bend the pins down about 20-30 degrees until they would insert into the OEM wiring. This wasn’t very difficult but it did take me a couple tries to get it right
Also worth noting, due to the little black piece of plastic holding the pins together, the OEM black housing would only snap into the one clip on the other side of the pins. Honestly, you could probably just get rid of the OEM black housings, but I left them in there.
This is with the new LED’s installed
Snap them back into place, then repeat with the other 3 doors.
Front Turn Signals
Remove the two push pins that hold in the black trim piece right above the grille, and pull out the trim piece.
Remove the rubber bushing that I am pointing to on both headlights.
For the pass side I had to remove the airbox to gain access. Use torx bits to remove the two screws on the right side of the air inlet, and one screw on the left side of the inlet. THIS STEP IS NOT NEEDED ON THE DRIVER SIDE. After removing the screws, the airbox can be pulled up and out. You also have to loosen the air inlet clamp and pull the inlet tube out of your way.
(Right side of air inlet)
Left side
This is the hardest part due to limited work space. You have to jam your had inside the little hole and twist the bulb socket clockwise until it pops loose, then the bulb can be removed.
Install the new LED, and reverse the steps to reinstall/put everything back together.
Reverse Lights
Puddle lights
Front Turn Signals
Left side
LEDs are an investment.
Check out www.deAutoLED.com to see all our LEDs available!
LEDs:
-Are an upgrade to any car
-Creates a more appealing & modern look to your car
-Are safer and creates a more enjoyable riding experience
-Our LEDs come with a Lifetime Warranty!
This is one of the few mods that will normally add to your car’s resale value!
LEDs:
Bright error free LEDs:
194 10pc CREE LED Reverse LED Fits:Audi A3/S3/RS3 + Many More | deAutoKey
Attachment 100792
Attachment 100792
Thanks for the orders and support - if you have any questions our friendly staff is virtually available 24/7:
www.deAutoLED.com
www.deAutoLED.com
Clean smooth OEM fade in/out with all of our Interior LEDs including trunk LEDs!
-our LEDs also WON'T stay dimly lit when your car is off!!
https://vimeo.com/101984748
See the difference with our LEDs and Customer service! Free shipping and lifetime warranty on all LEDs/HIDs!
See the difference, feedback like this makes bringing only the best quality LEDs and testing EVERYTHING we sell worth it!
FREE SHIPPING WITHIN THE US!
