Last edit by: IB Advertising
- Audi How to Use SD Card<br>Step by step instructions for do-it-yourself repairs.
MMI Entertainment Options Summarized
#442
Thanks for the great summary.
I have a question about the RCA/composite video input.
I am using an Mmi rca video in cable. However, the resolution appears to be quite fuzzy. The display area is also not maximised to the full screen.
Are there any settings I can play with to adjust?
I’ve tried both genuine and non genuine cables. Both yield the same result.
Videos I’ve found on YouTube appear to show that the full mmi screen to be utilised. But mine isn’t.
heres the video:
this is the same for me whether I use a HDMI to analog converter then to RCA colours, or when using direct output RCA from a device (example raspberry pi)
any help is much appreciated!
thanks
heres the video:
thanks
#443
It should indeed cover most all the screen. Check the video settings and whether you’re matching PAL or NTSC settings on the MMI and on the HDMI converter. There’s also a ratio setting in MMI that should be on 16:9.
#444
Thanks. I’ll have a look for the settings again, I couldn’t find them before..
HDMI converter works in PAL but when switched to NTSC, the image is too distorted.
its the same without the HDMI converter (rca output directly from device)
#447
Can you tell me where I can get my apps plugged into my C7A6? I'm looking for some mods to the software like needle sweep and colored ambient lighting. A few others like VIM as well. Thanks
