Outside temperature sensor location
Old Nov 21, 2017 | 07:38 PM
Jhsiah's Avatar
Default Outside temperature sensor location
hi guys first post here , here I have a 2017 A6 2.0 , my first Audi and experience so far has been great . Now , long story short I hit a bag of soil while going 65 mph on freeway , pulled it aside and visual inspection confirmed damage only cosmetic. My lower side grill flew off and tempuerture sensor was missing in action which also the case for various light came out namely engine ligh, electoral brake and tpms malfunction , got a new sensor and holders it’s all good now. I am puzzled finding the location for the mounting the sensor bracket, can someone tell me the exact location ? Pictures if possible will be much appreciated as it makes things easier. Thanks all
Old Nov 22, 2017 | 06:52 PM
engleg's Avatar
I think that this is the temperature sensor holding bracket on my MY2012 3.0t.
Lower passenger front grill area.
Old Nov 22, 2017 | 07:38 PM
Jhsiah's Avatar
Awesome ! Excactly what I was looking for thank you !
Old Feb 20, 2018 | 06:41 AM
JackA6's Avatar
I checked the center grill passenger side on my MY2012 A6, no sensor to be found
Old Feb 20, 2018 | 10:56 AM
tenspeed's Avatar
On the 2012 A7, the sensor is in the lower right side of the main grill. The sensor itself is behind a bar and I can see the mount.
Attached Thumbnails Outside temperature sensor location-100_0989.jpg   Outside temperature sensor location-100_0991.jpg
Old Feb 27, 2018 | 08:34 AM
JackA6's Avatar
What steps did you use to repair and replace this part?
Old Feb 27, 2018 | 08:35 AM
JackA6's Avatar
Thanks a lot, but it wasn't the same on the A6
Old Feb 28, 2018 | 01:55 PM
JackA6's Avatar
Is that it?
Old Feb 28, 2018 | 02:42 PM
JackA6's Avatar
This is the view under the radiator cover on A6 2012
Old Feb 28, 2018 | 08:32 PM
engleg's Avatar
I also don't see the temperature sensor in any of your pictures. Even if it has fallen it seems like it should be visible.
The lower front grill is where it should be as far as I know on the U.S. models.
I removed the upper front-end cover to see what mine looks like. I can't see the temp sensor because it is hidden below the bumper.
My wiring harness splits and one set of wires goes to the garage door opener control module, and the other set of wires goes to the temperature sensor.
Attached Thumbnails Outside temperature sensor location-dsc_0442.jpg   Outside temperature sensor location-dsc_0449.jpg
