- Audi A6 C6 Known Issues and Reliability<br>Important information to help you understand your Audi A6 C6.
Reliability Problems Of The 3.0 Supercharged Engine?
Again, thanks for the input and reassurance.
http://www.insideline.com/audi/a6/20...rst-drive.html
Consumer reports has been kind to the new generation A6, and for several years they had it recommened and gave it a thumbs up.
The A6 is pretty rock solid.
Although I had 4.2 v8, I had no realiabilty issues with my 2008. All I did was put gas in it and go for almost 3 years. Never a electrical glitch, check engine light...nothing in the time I owned it.
The 09 was the 1st year of the S/C engine. So it's expected you might have a few glitches here and there.
If you car dies from a bad water pump, it is a fault and something that needs to be addressed.
But for anybody to say the new generation 05 & up A6's are generally "abismal" - doesn't know what they're talking about.
So, in short -- (1) don't shoot the messenger and (2) work on your reading comprehension.
I see this in all consumer products ranging from cars to washing machines to TVs, if they believe they are buying the best then they think it should never give problems, but the reality is that all things electrical and mechanical do break down from time to time regardless of the brand.
If you think for one minute that Audi are any less reliable than Mercedes, BMW, Jaguar or Porsche then you are wrong because they all use the same sub-manufacturers to supply the parts which make up the cars you drive, if theres a difference it's coming from post assembly, meaning the dealer network.
I run one recently before handing over to my brother and between both of us we haven't experienced any problems at all. Maybe we are the exception to the rule but I feel if it's record is indeed as bad as you are claiming then this vote should reflect this.
As a 3 time Audi owner and 2 time A6 owner (06/08/11 models), I have had good expereience with my A6's.
The people that are angry in life usually let a lot of people know about it. There is a lot of technology on these cars. User error and "ghost problems" are counted against the manufactuer and people complain about a lot of things.
Some are very valid, and others not.
If you can't handle the emotional stress of owning an A6 because Consumer Reports says not to, then maybe you should go buy a Subaru.
