Any way to remove the "remote access rights" screen on MMI startup
New S6...every time I start my car I have click "continue" on a MMI prompt screen that states "Welcome, (my name) has remote access rights. "
Why would I possibly want to have to click continue to this prompt every single time I start my car? Is there a bypass for this?
DadAudi (04-14-2021)
Check the privcy settings in the user profile. I don/t get this message on my 2019 car but maybe it will be a new "feature" when I get my 2021 car in the next week or so
Is your car MIB-2 or MIB-3? The OP with a new S6 is almost certainly on MIB-3 (identifiable with 2 USB-C sockets in the arm rest and no SIM or SD-Card slot) It is likely that the software for two systems will be different, ven if they look the same from a functionality perspective
I have just chnaged my 2019 C8 for a 2021 C8 and you indeed get the screen on start-up. If you just drive off the screen clears after a few seconds - no pressing required, Alternatively if you want to get to a function you can press the Home icon on the top RH (on my UK car at least) corner. This is clearly a change between MIB-2 and MIB-3, on my 2019 model the screen about which user was logged in came when you switched the car off. My wife's Golf8 is the same as the new A6, witht he screen on start-up, I guess basically giving different registered drivers the abilty to quickly have the means to change to their stored profile. If you are the only driver then it is a bit redundant
JimOB
03-11-2001 04:10 PM
