01 A6 2.7T power steering fluid magically disappeared
I have a 2001 A6 that has a constant power steering fluid leaks. I just had a shop check out the power steering rack and all of the lines and there is no indication of a leak at all. My reservoir will go from filled to the top to empty in as little as three hundred miles. Where could this fluid be going?
The only thing worth mentioning is that the low pressure return to the reservoir is made out of radiator tubing, I will need to get that replaced since the mineral oil can degrade that line.
Thanks
Thanks
Get some UV-detector dye and a UV light.
Thanks
Thanks
It's been raining and my driveway is mud so my options to investigate are limited at the moment.
IF you have a belly pan drips can be problematic to isolate.
Only cure for the rack leak is to replace the rack, unfortunately.
Cargasm2.7
11-10-2005 03:44 AM
osuidoc
06-06-2005 06:42 AM
ChrisS -2008 A6-4.2
11-14-2000 11:27 AM
