'01 A6 2.8 Quattro Wierd no start
Hence I specified "not threaded view".
But yeah, the OP did mention the ESS. Which is easy to read in non-threaded view.
Thanks
Steve
Most likely the sensors were heat soaked and raising the hood allowed for the sensor to cool off. I'm betting that this only occurs on a hot engine and that the problems goes away after 10-15minutes with the hood raised. From the code reader I would replace the speed sensor.
It turns out that the "engine speed sensor" and "crankshaft position sensor" are the same part # on the 2001 Audi A6 Quattro automatic. I found an new OEM sensor on-line for about $60 delivered. As audiqv8 says, it is important to get the right one for your transmission.
To change the speed sensor: Remove left front wheel. Locate and remove "engine speed sensor" just in front of left front axle with 10mm socket. Remove coolant expansion tank. Locate gray connector on firewall and remove it from the bracket and disconnect. I ended up cutting the old sensor off and pulling the wire through the loom to remove it. Then fish-in the new sensor where it won't touch anything hot or moving and put everything back together.
On this model car, there is a spacer that fits under the ESS that must be removed from the old one and placed on the new one.
Thanks for all the help guys.
Steve
Steve
