04 2.7t little heat
Old Nov 2, 2012 | 06:11 AM
S8abmw's Avatar
Default 04 2.7t little heat
Trying to bleed after coolant flush. Had it running at 2100rpm. Bottom heater hose hot, top luke warm. Some heat, but when idle back to normal no heat. Removed top hose from firewall while running at 2100 rpm and only very light stream of coolant coming out. When I remove cap from coolant resevoir get lots of bubbling at 2100rpm, non at idle. Heater core boockage, head gasket or both? 273K miles. It runs perfectly
thanks,
Dave
Old Nov 2, 2012 | 07:11 AM
4Driver4's Avatar
Tech Guru
Tech Guru
It's a bleeding issue.
I bleed it cold with compressed air. Works great.
Old Nov 2, 2012 | 08:03 AM
Peter Badore's Avatar
Yes a bleeding issue. Try to find someone with a suction/vacuum pump. I think SnapOn's tool is called Vacula.
Old Nov 9, 2012 | 07:10 AM
slowguy's Avatar
Interesting on the vaccuum pump....I have one but where would you "suck" from?
Old Nov 12, 2012 | 11:18 AM
devinsixtyseven's Avatar
4D4 and Badore, care to elaborate?
Old Nov 13, 2012 | 02:40 AM
SloopJohnB@mac.com's Avatar
Tech Guru
Tech Guru
Fabricate an adapter from a expansion tank cap.
Old Nov 13, 2012 | 02:53 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Not to much to say...Fill tank, open bleeders, use an air gun and a rag to force some air pressure into the tank to push all the air out the bleeders. When no more air comes out the bleeders, shut them.
Old Nov 13, 2012 | 08:59 AM
Good tips. What can I say...I'd never done it, didn't want to create an inadvertent coolant eruption.
Sometime I'll tell you about the day I thought it would be clever to push the piston out of a monotube shock, using compressed air ...
ECS Tuning-Audi
S4 (B8 Platform) Discussion
Jul 26, 2018 02:02 PM
Kerry G
May 18, 2018 06:12 AM
visuar
TT (Mk3) Discussion
10
Nov 14, 2017 01:56 PM
ECS Tuning-Audi
Feb 4, 2016 08:36 AM
HZ60
Q5/SQ5 MKI (8R) Discussion
Sep 30, 2015 05:48 AM
