1998 Audi a6 quattro 2.8l. Code p1423
my Audi a6 2.8 Quattro is having a problem with the secondary injection system and I'm trying to find out with a combi those are located and has anyone else had any problem with this and fix it quickly I've already checked the lines and they seem good I'm going to check the pump in the fuses neck are there any advice that I could get
Please punctuate your sentence. It will make it much easier to decipher.
The combi valves are at the firewall side of the head. Look for vacuum lines leading to something that looks like a flying saucer.
Or, you could google "A6 C5 combi valve".
Here's what I found:
https://www.ecstuning.com/ES2913118/...y_xRoC-J_w_wcB
Sorry about my grammar as i was using google speech to text and okay i will have to check that again bc when i removed the engine cover i thought i found them in front underneath what looked to be the place where u put the firing order connectors at. I did follow the red and green vaccum lines to what i thought were the combi valves maybe they are just the egr valves for the car. Also its only pulling a code for the bank1 not bank2
Update
Hey guys, so this weekend im gonna check it out again and so far ive found that my saip(air pump) is not working on a cold start i did not feel any power move to it i will be checking the fuse in the ecu box underneath the hood tommorow and also im gonna double check my hoses but all my lines seemed in great shape for a 98 im considering that since its throwin a code for only one bank its not the pump. Does that sound right? Also its not a bad cat or a rear o2 i did just get my exhuast repaired after it leaking for a while
All right, thanks! I will check that out too by chance do u know which one is the relay? I can look in my owners manuial bc it has the diagram for fuses as well as the covers for ecu and fuse box. Im considering getting a vagcom as im new to audi world but they r alot of fun! Even the wagon i love but want like a RX8 XD
Ya this site is awesome but ive read a crap ton on forums about SAI and it has given me a bunch of info and with reading almost same thing ive been able to really get my mind around the system uve guys been alot of help. Ill post what i found out after work
Good luck with the repair.
