2002 a6 3.0L
OBD II will not give you the information you will need. (VCDS is a more extensive version specifically for VW/ Audi.) It will only give you CEL light codes. You need a VAG Com scan to read all the various systems on Audi. Obviously you do not need to scan to recharge the battery. All you need to check the charging system for function is a voltmeter. It should read around 14.2 volts at idle.
While the VCDS does EVERYTHING, this should be adequate for figuring out why your car won't start. That said, for a few bucks more, you can have the real thing that does EVERYTHING...
https://store.ross-tech.com/shop/vchv2_ent/
With no codes, we can only guess at the problem...so I will.
Battery issue needs to be resolved first. Since we’re guessing, start by buying a battery. Then do a throttle body adaptation (search) and see if that cures the idle issue.
