2002 audi a6
2002 audi a6
When I parked my Audi A6 turn the ignition to the Off remove key then I can pump the brakes and the dash cluster will light up and the radio will turn on the only aftermarket it electrical work that I see is a aftermarket USB Bluetooth how will I find what's causing that electrical problem because my battery is drained overnight with the car in the off position and the mileage light stays on all night
Difficult to understand without punctuation and some of the misspelling but as a solution the easiest would be to install a battery master switch and it is entirely possible that the after market blue tooth installation caused the problem a sticking relay may also be at fault you could hook up a volt meter and start looking for a battery draw or have it looked at by an independent shop what happens after removing the key if you don't pump the brake
.......it says press brake before starting...and press brake before turning ignition off....if i press brake....turn ingnition off....remove key....the odometer is still lit....i dont have funds for professional wiring YET....has new ignition switch......sonetimes the radio activates itself in the middle of night while im sleep....i dont have a volt meter either
i thought someone may know something about specific fuses or wiring spots to look at
Mr XhZ
07-12-2018 12:19 PM
josepvillegas
01-04-2018 01:37 PM
ayap
08-03-2011 04:08 AM
