2004 Audi A6 2.7T - Aux Water Pump Replacement
I read a couple of great posts about replacing the auxiliary water pump on the Audi A6, and am grateful that I found them to be so helpful. I am about to start the project myself and wonder if anyone is able to share the relevant Bentley manual pages to help identify various components as I step through this project and remove the intake manifold.
I haven't had a single reply. Am I doing something wrong? Perhaps I should be asking where I can download a PDF copy of the manual for a fee? I just thought that I had seen people ask for Bentley manual pages.
there's a diy description on this site. Not sure if it's in the tech articles or regular section. search the forum and try google. I followed the instructions from here. Basically you take the y pipe off and move or unhook vacuum hoses and then unbolt the intake manifold. I did not have to disconnect fuel lines and was able to tilt the manifold up to get easy access to pump. An audi tech told me that he pulls it out the back, but it's a blind reach.
Buy new intake gaskets and consider bypassing the pump with a section of hose. My pump has never run in 265k miles.
Verify the location of the aux pump
I have a 2004 a6 with the 2.7T engine and my aux pump is down by the A/CK compressor not under the intake manifold. I just have two hoses with a 90 degree elbow. Call the dealer with your VIN.
Most engines have it under the intake.
Engine repair manual for A6 C5 2.7L Bi-turbo
It's good idea to replace the intake manifold gaskets since they are metal.
I tried to attach a 5.5Mb pdf for an engine repair manual for the 2.7L Bi-turbo A6 C5.
Cheers,
Brian
Cheers,
Brian
Here's the link for many service manual: https://cardiagn.com/
There is a lot of click bait so beware.
Search the forum for diys. No need to pull valve covers. Intake manifold must be unbolted and tilted up on driver side. Just remove Y pipe and disconnect wires and hoses that may limit ability to raise intake. Get new intake gaskets.
Don't bother replacing pump, Just replace with hose. Hardest part is connecting hose to rear pipe, which is under oil line. Need long angled needle nose pliers to get at hose clamp. Bleed coolant when finished. Whole job takes a couple of hours.
