99 A6 Driver Info Display
Old Jul 26, 2009 | 06:49 PM
meyer73's Avatar
Default 99 A6 Driver Info Display
Does anyone know how to fix the Driver Information Display in the center of the instrument cluster? My screen is fairly illegible (pixilated) and I would like to repair it so that I can read the information that is displayed.
Old Jul 26, 2009 | 07:37 PM
radhaz's Avatar
The displays are pretty hard to repair without tools like a binocular microscope and very fine soldering tools. Best to send it to an outfit like modulemasters.com.
Old Aug 2, 2009 | 07:23 PM
meyer73's Avatar
Thanks for the help. I went to their website. It looks like they are more interested in selling software. Do you know anyone who has sent something there? There are two other firms listed on the web when I did some searching. One in Richmond (Southern Electronics) and one in Boston area (BBA Re-manufacturing). BBA charges $350. I contacted Southern, but have not heard back. Do you know anything about these other firms?
Old Aug 3, 2009 | 02:59 AM
4Driver4's Avatar
Tech Guru
Tech Guru
BBA rebuilds the whole cluster for $350, but if you contact them, they will do just the display for $115. ModuleMaster.com (no "s") does the same thing for $130.
Old Aug 4, 2009 | 04:40 PM
urs6_ma's Avatar
Does anybody have any experience with these shops? My IC is getting pretty annoying!
Old Aug 4, 2009 | 06:58 PM
4Driver4's Avatar
Tech Guru
Tech Guru
I had BBA do mine in both the A6 and the A4. The result is brighter than factory, but better than nothing. $230 to do both.
Old Aug 4, 2009 | 09:06 PM
nm3210's Avatar
I got word from a rep at modulemaster.com and they said that the next shipment of displays they are getting have a better-than-oem look: i guess better color/contrast, etc. (expected hopefully sometime in August 2009 here....)
To make things a little more clear, I'll try to explain about the screens a bit more. Many people have used a replica screen made in asia somewhere, and many photos of this screen have shown that it has very poor contrast which means that the entire screen is bright. I've heard from a few posts that people wish that they could turn down the brightness which is caused from a lack of contrast.
Another screen that has been used as a replacement is one that has been made in europe somewhere. This one is much closer to the OEM contrast and color brightness and looks much better than the asian versions. I know for a fact that the guys at modulemaster.com know this and are trying to find the best screen for the job. Supposedly they found a supplier that has a high-thermal property which means that this screen should last for much more than the one-decade that the OEM one did (hot/cold cycles has caused the most damage in these cars for me).
Here is a quote from the email I got from ModuleMaster.com on July 14th, 2009:
We discontinued the LCD repair because we ran out of LCD panels. While these were good LCD's (not the cheap Asian aftermarket ones), we have on order a superior quality LCD with much higher thermal properties. They can handle up to 300 deg. F and look just as good as the OEM in terms of color, brightness, and contrast. So it'll be well worth the wait. These LCD's also come with a lifetime warranty.
Old Aug 11, 2009 | 04:30 AM
meyer73's Avatar
I will plan on contacting ModuleMaster later in the month to get the new display type. This is great information. I didn't realize that they replaced the display in the repair process and that there were brightness issues.
Can I run the car without the instrument cluster without setting off some electronic alarms somewhere in the car? I may need to drive to work while it is being repaired. This would not be ideal since I would not have access to any alarm signals, but I am close to my office and the car is well maintained.
Old Aug 11, 2009 | 06:15 AM
nm3210's Avatar
Sorry, the car won't do a thing without the cluster in. It will be completely out of commission until you can put it back in.
Old Aug 11, 2009 | 07:40 AM
Donuts's Avatar
Not true for all cars. I ran my ’99 Avant for one week without the cluster while my LCD was being replaced but my ride does not have the Immobilizer security. I believe those that do have Immobilizer will be SOL.
If your car is one capable of being driven, you will throw a number of codes that will need to be cleared once you receive the cluster back and for that you’ll need the Vag-Com software.
All that said, I wouldn’t drive the car again without the instrument cluster. I took a calculated risk based transport needs and knowing my car's service history. I still scanned it before removal and also made sure all my fluids were topped off.
