ABS and YAW sensor codes???
So my ABS light comes on, the brake light flashes and the dash beeps. After a little while they turn off and the traction control light turns on, eventually it will also turn off then the cycle repeats, but randomly, cat seem to figure out what causes it. These are the codes im getting on a full system scan. Bad ABS module?? Ive check all connections and everything looks fine.
Address 01: Engine Labels: 078-907-551-AZA.LBL
Controller: 4Z7 907 551 AA
Component: 2.7L V6/5VT G 0010
Coding: 07752
Shop #: WSC 19303
VCID: 8277BD6E9D17
WAUCD64B44N083860 AUZ7Z0D2596010
3 Faults Found:
17861 - Exhaust Gas Temp Sensor 1 (G235): Open or Short to Plus
P1453 - 35-00 - -
17865 - Exhaust Gas Temp Sensor 2 (G236): Open or Short to Plus
P1457 - 35-10 - - - Intermittent
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 4B0-614-517.LBL
Controller: 4B0 614 517 H
Component: ABS/ESP allrad 3428
Coding: 06397
Shop #: WSC 02334
VCID: 263F41FED1FF
2 Faults Found:
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-10 - - - Intermittent
01424 - Yaw Rate Sensor (G202); Reference Wire
57-10 - Electric Circuit Failure - Intermittent
Coding: 07752
Shop #: WSC 19303
VCID: 8277BD6E9D17
3 Faults Found:
P1453 - 35-00 - -
Coding: 06397
Shop #: WSC 02334
VCID: 263F41FED1FF
2 Faults Found:
LordKarnage17
10-17-2017 12:09 PM
