Acoustic Park Assist
Need help diagnosing the acoustic parking assist feature;( it's the intermittent sound you are supposed to hear when backing up to make sure you avoid backing into something)
Vehicle is 2000 A-6 2.7 bi turbo.
How can I tell if one or all of the rear sensors are bad?
I get the brief tone when placing transmission in reverse but do not get any sounds as I get closer and closer to objects while backing up.
Is this something I can diagnose and fix myself without dealer involvement?
Thank you in advance,
Kurt
Kurt
Thank you George
Are the items you refer to, a VCDS or a VAG5051 pieces of equipment that are affordable for a do it yourselfer like me or are they for repair shops only and therefore cost prohibitive?
Also, is there any kinds of software for a laptop that would do what the above items do and that is reasonably priced?
I appreciate your help,
Thank you
Kurt
Thank you
Kurt
Probably the most popular is the Ross Tech VCDS. They sell you a connection cable and software subscription for around $200 . It only works on PC's (laptops). Unless something has changed recently, not available for Mac. Windows machines only.
I bought my VCDS from Ross Tech in 2003 to diagnose a difficult problem on my 2001 A6 2.7T and it has paid for itself many time over, not only on my cars but also on the cars of my friends. Over the years, probably has saved me $5000 in diagnostic fees. Without it, you are shooting in the dark with blanks.
Gentlemen,
I am 71 years old so this technology is a challenge, however I looked up the Ross Tech VCDS Lite which they claim is freeware.
Would this be good enough for me or do you think I need the paid version.
(My older cars are easier to work on, but I guess that is just me showing my age)
Kurt
Kurt
George can correct me if I'm wrong but I believe you need their cable to utilize the software. "Freeware" indicates software that is maintained and developed by users' input and other sources. There are other scan tools out there but they will not read all the Audi system components. (i.e. transmission control module, ABS module, etc.) If you can handle online banking, bill pay, shop on Ebay, you can master the diagnostics with this system. The trick with technology is DO NOT guess about stuff. If you are unsure about something, stop and find the correct path to proceed. You can do this!
Gentlemen,
Kurt
Kurt
Functions - Ross-Tech Wiki
Don't worry, Kurt, 71 is the new 50... (full disclosure, I had to take my required distribution from my IRA this year.)
Cheap Solution
You can buy a cheap adapter on eBay for under $10 that will work with the VCDS freeware. Like this one:
https://www.ebay.com/itm/USB-Cable-V...cAAOSw55FcQs5p
or just search eBay for "vcds cable". I have an '01 A6 and the ebay adapter works just fine with it. You will need a laptop to use it.
I have this OBD2 adapter:
Does anyone know if this sort of adapter will work with VCDS Lite? (assuming my windows laptop has bluetooth and I pair it successfully of course)
