Anyone have any recommended spark plugs?
Old 10-07-2008, 06:37 PM
  #11
Paracaidista2.7T's Avatar
No, but I learned it from some of the S4 guys who learned the hard way.
Old 10-07-2008, 06:39 PM
  #12
FWIW, I run NGK Copper BKR7E, I just change them every 7500 miles or so. I gap them at .28
Old 10-07-2008, 06:53 PM
  #13
Grapeking's Avatar
Gracias.
Old 10-07-2008, 06:55 PM
  #14
De nada.
Old 10-07-2008, 07:00 PM
  #15
GeorgeInVegas's Avatar
How did you come up with .28? That doesn't line up with Audi's suggestion.
Old 10-07-2008, 07:06 PM
  #16
Default In short, my car is "slightly" modded. This gap works well for my combination of mods and boost
levels.
Old 10-07-2008, 09:25 PM
  #17
TGK
TGK's Avatar
Default I broke a mm off 1
They are simple to break! But seemed real strong when I first put them in..Chipped A6 2.7T
Old 10-08-2008, 07:08 AM
  #18
Member
S4_Cinci (I S'edTFA)'s Avatar
Default I learned from talking to a tech at NGK that the PRF6Q plugs that came OEM on 2.7t engines, have the
lowest resistance of any plug NGK makes. When I asked about equivalent plugs in Iridium or non-exotic metals, he told me that there is no other recommended plug or equivalent for this OEM plug due to the resistance value. Could be BS or it could be true, but I tested the BKR7E and the Iridium IX in that size and heat range and the resistance was significantly higher than for the PRF6Q plug. My conclusion is don't use anything else for the 2.7t application unless you have a VAG-COM and your coilpacks are in great shape!
Old 10-08-2008, 07:10 AM
  #19
Member
Default I have these in an older Acura and they are running great for 20k+ miles now. No Audi/Vw experience
but my plan is to put them in a 2.8L 30V ATQ engine very soon.
Old 10-08-2008, 08:50 AM
  #20
2.7T_RT(toofast)'s Avatar
I trust my local Audi Certified Indie. OEM all the way on plugs.
A4QuattroV6
07-25-2011 04:48 PM
MarkItZero
Q7 MK 1 Discussion
10-22-2008 10:41 AM
richmonds4
03-03-2008 02:44 PM
Bariukas
01-10-2007 05:34 AM
DesmoTesta
08-03-2006 06:51 AM
Quick Reply: Anyone have any recommended spark plugs?
