Anyone test/repair air bag modules?
#11
The $32 fix
Found a voodoo box on the internet that said it would fix it. Cost me $32. It worked. The light has been off for 2 months. (Hope this does not jinx it) If you want to put the original module back in place this might work for you. No promises.
VAG OBD2 II Airbag Crash Resetter Tool for Audi VW from Tmart.com Google this and it will show up. Or search this forum for my original post on 2/4/2013 title "recurring DTC 65535"
good luck
#12
I went through this DTC 65535 issue a year ago and then again a couple of months ago. Found an outfit in Sudbury Ontario that reset the module last year. They were the only people I could find who would reset this specific fault. Worked for a year and then the same code came back. I did not want to go through the process of tearing apart the console again only to have it re-occur in another year.
good luck
good luck
#13
You may well be right. You certainly sound like you know what you are talking about. All I have is anecdotal. I tried it; it worked. If it comes back, I will try the voodoo box again. It just plugs into the test port used for the VCDS. Took me less than a minute to turn off the airbag light. If it eventually quits working, meaning it no longer turns off the light, then I am out $32. Then I will consider buying another module.
I appreciate the info about what is happening. Sounds like the only long term fix is another SRS module.
I will report back if my cheap voodoo fix fails.
#14
It sounds like that box pretty much just reflashes the processor! Well it is a solution. I'd say keep using it until the SRS module quits. No point in buying another one if this one is still semi-alive!
#15
