AutoTrans Code errors
I was on my way back from school and the transmission slipped and the RPM's skyrocketed. I wanna say maybe gear 3 slipped. After that, the car would slowly go into a limp mode(Neutral in every gear besides park). Prior to this incident, the car did not give me trouble on my way to school until right around when I was entering the premise. I struggled to get my car home; I Kept having to pull over my car turn it off, then clear the codes with my laptop on Vagcom. I did this same procedure again and again until I made it home. on straight roads where I was just in one gear the whole time I seemed to get far, but if I took my foot off accelerating the car would slip then shortly after the slip go into a coasting neutral state at which I would quickly have to pull over and reset the code.
After Searching the various codes that show up, I could not find any direct solutions.
Can anybody assist me please?
Vagcom Codes:
Address 02: Auto Trans Labels: 01V-927-156.LBL
Controller: 4B0 927 156 G
Component: AG5 01V 2.8l5V USA 8509
Coding: 00000
Shop #: WSC 00000
VCID: 2B296E89CA1D
5 Faults Found:
00652 - Gear Monitoring
27-00 - Implausible Signal
00526 - Brake Light Switch-F
01236 - Shift Selector Locking Solenoid (N110)
31-10 - Open or Short to Ground - Intermittent
00293 - Multi-function Switch (F125)
27-10 - Implausible Signal - Intermittent
00668 - Supply Voltage Terminal 30
31-00 - Open or Short to Ground
