BAD Coolant Leak !!!
Old Oct 14, 2011 | 07:58 AM
wayneraymond's Avatar
Default BAD Coolant Leak !!!
my 2000 Audi just started to leak recently & it was only dipping at first, now it pours out as soon as i fill it up. I was wonderin if any1 could help me out. I can;t seem to find the leak. Its leaking on the driver side behind the turbo, between the engine & the transmission. I was wanted to know if this is a common problem.
Old Oct 14, 2011 | 09:13 AM
2.7Lturbo's Avatar
aux coolant pump, very common.
Old Oct 14, 2011 | 10:23 AM
i'm gonna check that but i'm pretty sure its something different. do you have any other sugestions
Old Oct 14, 2011 | 11:31 AM
5v/cyl's Avatar
Why are you so sure it is something else? Aux pump is common. A leak that pours out should be easy to find.
Old Oct 14, 2011 | 03:43 PM
everything is so tight you cant really see the leak unless you disconnect & move stuff around. thanks for the help. i'm gonna check it out 2morrow.
Old Oct 14, 2011 | 06:33 PM
i took all kinds of stuff apart and i can not find that leak anywhere
Old Oct 14, 2011 | 06:38 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Did you check the pump as suggested?
Old Oct 14, 2011 | 08:48 PM
Bradw's Avatar
could be the thermostat housing mine just cracked too
Old Oct 14, 2011 | 09:44 PM
therealmikeg's Avatar
I'm guessing not.
Wayne, your symptoms match my own. When I finally got the APR bi-pipe off (*sigh*), I stuck my hand in between the manifold and the engine and found that my pump had literally fallen apart.
If you're going to DIY, here's a few guides you should look at first...
Removing the manifold method:
https://www.audiworld.com/forums/sho....php?t=1526828
Without removing the manifold method:
https://www.audiworld.com/forums/sho...php?p=13870560
https://www.audiworld.com/forums/sho...php?p=14547593
Old Oct 16, 2011 | 12:54 AM
isleblue65's Avatar
Probably not, since the thermostat housing is under the timing belt cover, under the water pump at the front of the engine (on a 2.7t), and his is leaking at the rear passenger side.
I did my auxilary water pump a few weeks ago the long way, by removing the intake manifold. I don't think my hands are small enough to do it the way described in the threads linked previously. Wow! I didn't replace my hoses, but replaced all clamps with worm clamps. No more leaks.
