CAM SPROCKET HELP
#12
#13
interesting enough, i found a timing gear puller on that website as well. it looks like it could work too. i'm going to rent both after work, then complete the job already.
#16
i couldnt get the sprocket off. i dont really see a way to get them off with a hammer. i wonder if a harmonic balancer pulley puller would work because the posi lock isnt long enough.
#18
I trust you, so today I'll try your hammer method. I really must admit that I'm very nervous about it.
How hard should I hit it?
Which hammer should I use?
#20
and the sprockets should just pop off? i'll try once i leave the office.
when i loosen each bolt, how much of a gap should there be between the washer and the sprocket? 1/16 inch? 1/8 inch? 1/4 inch?
