Changed O2 sensors and still got codes...
2001 A6 2.7T
So, I changed out both the 16067 and 16069 O2 sensors and I still get the following codes:
P1113
P1131
P1136
When getting to highway speeds I get a flashing ESP light and ABS light comes on and power loss (engine seems to bog down then work as advertised intermittently. If I push the ESP button in on the dash, I don't get any power loss going up to highway speeds and the ABS light does not come on.
I just replaced the timing belt and internal water pump (yeah, that was a fun job).
I have the older (original) VagCom tool but that laptop is now dead so that is useless. I had to use a cheapo reader to get the above codes...
I reset both connections on the O2 plugs.
P1113
P1131
P1136
if your abs module seems to be faulty (they fail quite often), then you can have it rebuilt so you have a warranty. I sent mine to bba-reman for my c6 and they did a great job. but don't buy their service from their site, look on ebay, at least that's where i found it 100 bucks cheaper.
Classic ABS ecm failure. Inexpensive repair.
2001 A6 2.7T
P1113
P1131
P1136
P1113
P1131
P1136
the ABS ecm can be removed and the car driven (won't have ABS and might have rear-wheel brake bias…be careful until you figure out what happens). Just wrap the exposed solenoid buttons/ABS unit in thick aluminum foil and cable tie it.
swizol122
12-09-2012 05:27 PM
GreatitaloS4
11-20-2010 12:22 PM
JMS-Four
01-30-2010 07:42 PM
