Clear code, or not to clear code
Old Aug 4, 2011 | 09:43 AM
Philhawtin's Avatar
Default Clear code, or not to clear code
I just put in an CELiminator, from Vast. Will my CEL clear itself? the only existing code is for the main catalyst fault. Id rather it clear itself to get emmissions done quicker, if that is the way it works other than clear all codes and complete drive cycle before being able to DEQ.
Thanks for the help
Old Aug 5, 2011 | 07:40 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Clear the codes so it can set the readiness.. 02 codes don't tend to clear themselves.
Old Aug 5, 2011 | 08:24 AM
Philhawtin's Avatar
So I just had the cel come back on. guess its time to replace the cat :/
Old Aug 5, 2011 | 09:15 AM
Head Cat Herder
25 Year Member
how new are the 02 sensors?
Old Aug 5, 2011 | 09:24 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Or something. What code(s) are you seeing?
If just cat, can you force readiness on everything else and get through emissions that way?
Old Aug 5, 2011 | 12:52 PM
Philhawtin's Avatar
pre cat o2's are brand new.
bank 1 main catalyst fault code : 16806 - Main Catalyst; Bank 1: Efficiency Below Threshold
P0422 - 35-00 - -
only code by the way.
And the rediness button is shadowed out. no option to set rediness..??
Not sure why. i put the fouler on the bank 1 post cat sensor. cel came back, I cleared codes an hour ago, waiting for drive cycle to complete - see if it comes back. Any other ideas?
Old Aug 5, 2011 | 12:56 PM
Philhawtin's Avatar
Am I trying to set rediness wrong?
Also... JUST CONFIRMING, Bank 1 is passenger side right!? (hoping im wrong at this point)
Old Aug 5, 2011 | 05:17 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Bank one is passenger side in the US.
Check the VAG-COM site to see how to force readiness. Takes about 20 minutes.
 Pouria Savadkouei
 Michael S. Palmer
bl97
Nov 25, 2005 08:43 PM
ivans A8
Nov 4, 2005 07:16 PM
George @ BostonAudi
Mar 31, 2003 10:14 AM
Simkin
May 1, 2002 09:24 PM
