The cluster?
Old Jul 18, 2013 | 01:20 PM
  #11
Li3ny's Avatar
Default It won't mess up your mileage.
The dealer puts in the correct mileage when they code it. And so no issues on the title. That's why I figured for $60 (or whatever his dealer charges him) he could be fixed.
Searching the forums in AW has always been a huge help to me. Especially when there are common issue's like this one. Although I'm sure they have also pointed me in the wrong direction at times as well. I chalk those up to preventative maintenance.
Old Jul 18, 2013 | 01:25 PM
  #12
GTA_Driver's Avatar
Tech Guru
You cannot recode mileage on a used cluster. Only a brand new cluster that has less than 100 km or miles on it.
Old Jul 18, 2013 | 10:14 PM
  #13
lucio_liu's Avatar
second this, code a used cluster with less mileage is illegal here.
Old Jul 19, 2013 | 04:25 AM
  #14
GTA_Driver's Avatar
Tech Guru
Technically, the cluster won't allow itself be recoded if it has more than 100 kms on it. It's a technical limitation. So the dealer physically won't be able to recode.
However, there are some underground tools that can.
Old Jul 19, 2013 | 04:29 AM
  #15
Li3ny's Avatar
Default My dealer set my mileage on 2 different used clusters.
My RS6 cluster came with 60K on it they programmed it to 140k. (which I was hoping they wouldn't) And my A6 used cluster had 200k on which they brought down to 140K. (Which was very nice of them)
I was a licensed inspection mechanic in NY & currently am in PA. Never heard of any such laws.
The dealer didn't even bat an eye....took care of it in less than an hour.
Old Jul 19, 2013 | 07:15 AM
  #16
GTA_Driver's Avatar
Tech Guru
Really? That's interesting. Maybe it's the laws in Canada/Ontario, but this has been corroborated by many others. The way I understood is that the cluster has a security mechanism that will not allow itself to be reprogrammed unless it's under 100 kms.
Wonder if they're using "unofficial" tools for that job...
Old Jul 19, 2013 | 07:21 AM
  #17
GTA_Driver's Avatar
Tech Guru
Ross-Tech agrees. On their page regarding cluster swapping. See the last sentence.
So how did your dealer recode a used cluster? I doubt via the official Audi means.
[Select]
[17 - Instruments]
[Adaptation - 10]
Enter "channel number" 09 to select channel
Put in the number of km divided by 10. Example: If old cluster had 50,357 km, put in 5036.
Note: Some clusters may require a Login of 13861 before you can set the mileage.
[Test]
Observe the Instrument Cluster and make sure the mileage displayed is correct. Once you save this value, you will be unable to change the mileage EVER!
[Save]
Old Jul 19, 2013 | 01:12 PM
  #18
ddillenger's Avatar
I can recode a used cluster. When I sell units with new LCD's I generally ask for the owners mileage, or send them out with 0 miles and a login code so it can be done via VCDS.
Old Jul 19, 2013 | 01:21 PM
  #19
SloopJohnB@mac.com's Avatar
Tech Guru
Tech Guru
Generally illegal only if you deceive as to the mileage.
Most states if not all have a disclaimer where you state the mileage on the odometer is not the actual mileage.
Intent to deceive is extremely difficult to prove....
Old Jul 19, 2013 | 05:06 PM
  #20
Li3ny's Avatar
Default Just my personal experience
I don't know how they did it. The service manager is a friend, he didn't mention anything special was required. But he is a friend so it could have been.
They where worried about the RS6 cluster working properly in the A6, but it functions perfect.
