Driver Door Sagging
Old Oct 15, 2007 | 08:27 PM
GIAudi's Avatar
Default Driver Door Sagging
Any help on adjusting the driver's door on my '00? The aluminum molding is no longer aligned with the rear door. This is causing the door to not shut fully/properly and you can see a noticeable "drop" when opened. No damage history on the car either. Is it just age related? Any quick tips on aligning it?
Thanks All!!
Old Oct 15, 2007 | 08:52 PM
BoneDaddy's Avatar
Default do you mean the "chrome" trim around the windows?
I don't have any tips as I haven't had to do anything to mine, but maybe if we better identify the piece others may chime in.
Old Oct 16, 2007 | 04:23 AM
Boston Driver's Avatar
AudiWorld Expert
Probably need to adjust at the door hinge, but I would leave that to a pro.
Old Oct 16, 2007 | 04:58 AM
Edd W's Avatar
Default The hinge pins are replaceable but the hinges are neither adjustable or replaceable.............
If it the window frame whihc has moved it is straightforward to adjust once the trim panel is removed.
There are four bolts - two on each end, one upper and one lower. There are some shims which can be used to move the frame once the bolts are slackened.
Old Oct 16, 2007 | 05:18 PM
GIAudi's Avatar
Can any body shop accomplish this or should I find a specialist??
waxio
13
May 6, 2014 08:14 PM
dubblrest1985
Audi allroad
Jun 20, 2013 01:06 PM
JEMiller
Oct 18, 2007 08:33 PM
Holographic77
Mar 21, 2007 02:52 PM
