drivers door wont open!!
i unlock my car, the door wont open....the lock nub on the door is up so its unlocked, bht door wont budge. anyone else have this problem?
i have the vag coded where it locks and unlocks past 15 mph and when i turn the engine off~. had it for a while with no problems. could that be the problem? will it show if i vag it? anyone in so cal wanna vag it for me tomarrow? hehe
Assuming you are out of warranty...
Take the door panel off. You will find a steel rod connecting the door button to the electric plunger/solenoid to the doors handle, etc. Sometimes this rod can slip out of the button or the solenoid. Just re attach it and give it a little bend tighter with pliers. Try the lock b4 you re assemble the panel.
It's not a hard fix.
Re: drivers door wont open!!
Make sure the lock **** is fully raised by pulling up on it. You will probably need something to grab onto it with, as fingers just slip right off. I have seen a number of these, the lock rod raises but not all the way. Try that first because you pretty much have to destroy the door panel to get it off with the door closed.
Kingttr
12-05-2006 08:47 AM
