Drivers door won't shut & a couple of Vag-codes
My drivers door is only closing onto the latch and not shutting properly, I did a scan with vag-com tonight and it came up with the following codes.
Address 35 -------------------------------------------------------
Controller: 4B0 962 258 H
Component: Central Lock/Alarm D33
Coding: 04810
Shop #: WSC 02325
3 Faults Found:
01562 - Right Rear Door
59-10 - Can't Unlock - Intermittent
01559 - Drivers Door
60-00 - Won't Safe
61-10 - Won't De-Safe - Intermittent
This morning was the first time it has happened. Anyone any ideas
Coding: 04810
Shop #: WSC 02325
3 Faults Found:
60-00 - Won't Safe
Lube it. The door latch is 100% mechanical. either the cable is binding, or the latch itself..
There's a small sliding bar in the latch that does tend to get gummed up, and cold weather makes it worse.
Re: Drivers door won't shut & a couple of Vag-codes
Depending where you live, cold & heavy spray grease do not get along, will make it worse in the cold. If it has been lubed with a heavy oil or spray grease, flush mechanism clean with WD-40 or similar. Then use a sparay graphite to lubricate.
shadyraven
Audi allroad
02-17-2009 05:58 PM
audi2.7audi
11-29-2005 12:42 PM
DBZ
Audi 100 / A6 (C4 Platform)
02-20-2005 11:23 AM
ECUAJEY
05-13-2002 05:56 PM
