Drivers Window Switch
Old Sep 9, 2008 | 07:51 AM
vino's Avatar
New Member
Default Drivers Window Switch
Our child control button stopped working on our 2001 A6 windows. So we'd like to replace the switch. I have the new switch, but need to know how to remove the old one - anyone care to help? I've seen reference to the small hole, but any picture of what I'm aiming for?
Old Sep 9, 2008 | 09:17 AM
2000 A6 2.7t 6m's Avatar
Default The hole is on the underside of the handle below the switch, hard to miss.
Place a small screwdriver, or anything that will fit up there, and you should be able to push the switch out.
Old Sep 9, 2008 | 09:38 AM
vino's Avatar
New Member
Default Re: The hole is on the underside of the handle below the switch, hard to miss.
we'll give it a shot and let you know. We were hoping for some type of clue what we are trying to reach - i.e. a plastic tab that could break, a metal clip.....
Old Sep 9, 2008 | 11:12 AM
Default There is a plastic tab on the front of the switch...
You should be able to see this on the new switch you are putting in. I only found this out after I removed the switch the first time, so pushing it in is not required, though will make it slide out instead of "snap" out. I have a MY2000 and was not very gentle and nothing broke.
Old Sep 10, 2008 | 12:50 AM
SloopJohnB@mac.com's Avatar
Tech Guru
Tech Guru
Default Ahhh..good news. I have same prob on 2000 4.2A6.
I didn't want to fool with it because I thought it was a full assembly. Now I'll get the switch.
Old Sep 10, 2008 | 06:14 AM
vino's Avatar
New Member
Default Re: There is a plastic tab on the front of the switch...
Thanks! Took longer to get the switch unit out of it's decorative cover without breaking the old brittle plastic (it's a 2001 A6) but it's in and my friends now control their own wind - if I give them permission via the switch. Thanks.
Maini
Jul 14, 2008 10:53 AM
s4sd2007
Jan 7, 2008 07:33 AM
AndrewWK
Audi Original "S" Cars
Jan 17, 2007 04:33 AM
SmokinM3
Audi 100 / A6 (C4 Platform)
Oct 24, 2004 09:23 PM
2.7 Husky
Jul 21, 2004 02:33 PM
